2007 Prius A/C Not Cold Enough
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Aug 29, 2017.
  1. tampaite
    tampaite Member
    237
    42
    FL
    Placed a 1-day shipping from Amazon for the coolant. Came out to the $26 + tax for 1 Gallon
    Toyota Genuine Fluid 00272SLLC2 Long Life Coolant
    Still looking for the R-134a online. The OReilly Auto parts link doesn't show a photo of a gauge so not sure if the price includes the can along with the kit.
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    again there is no kit.. just a can
    edthefox5 likes this.
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    And the system would NOT be low on refrigerant if there is not a leak somewhere.
    Have you tested it by turning the temp down yet ?
    Or are you just stuck on recharging whether it really needs it or not ?? :whistle:
  4. Beachbummm
    1,160
    392
    I gave up on this post, a lot of people come here for free advise then do what ever they want to anyway.. not worth the time..
  5. tampaite
    tampaite Member
    237
    42
    FL
    I think a little patience is called for since PC.com has been having issues. I cannot login nor post for few days now
    The following error occurred:
    An unexpected database error occurred. Please try again later.
    Anyway, turned down to 65 and still it blows air but not cold enough...
  6. Sam Spade
    2,036
    1,024
    2017 Prius c
    Take it to an auto AC shop.
    Doesn't have to be a Toyota dealer.
    Should NOT be somebody who works out of his garage at home.
    #26 Sam Spade, Sep 2, 2017
  7. JC91006
    16,936
    8,647
    No eco mode in gen 2
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    Edited my post. Thank you.
  9. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    My last on this...take it to the Dealership. Let Billy Bob's A/C Service "learn" the Prius on someone else's dime. ;) Wish you the best.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Rad Overflow is empty probably because you have a leaking engine water pump. Pretty common. Take the black plastic cover off the top of the rad to expose the radiator cap. Take the cap off. Rad is probably pretty empty too.
    Having owned my car for 10 years since bought new the overflow has a full line on the overflow tank. Hold a flashlight up to to the tank and you will see the FULL line. You can highlight that line with a magic marker that helps. That fluid level on that line will never ever change from the full line. If it does you have a leak.
    If blowing not cold the condenser on the front of the rad may have never been cleaned. or you may have a bad ac aux fan. Put the ac on MAX HIGH both electric fans on the rad should be on. Really loud. Slamming freon into the system from a $20 bottle from autozone wont do anything except maybe damage the system. If refrigerant is low its becasue you have a leak.
    Take it to ICE COLD AIR they do Prius all day. Its about $100 to charge- inject dye- and then sniff and uv test.
    Cheap.
    Prius with no ac is undriveable in Tampa imho. I'm there everyday holly crap its hot.
    Call Todd at TampaPrius.com and ask who he goes too.
    ukiltmybrutha likes this.
