2007 Prius battery
Discussion in 'Gen 2 Prius Main Forum' started by Dillo13, May 28, 2014.
  1. Dillo13
    Dillo13 New Member
    My 2007 Prius has 135k miles and I suspect I'll need the big battery change soon. How do I achieve that without the high cost everyone has been telling me about? After all these years, hasn't Toyota - or someone else - discovered a way to change the battery for less than $3,000?
  2. Scallywag
    Scallywag Member
    107
    22
    Columbus, OH
    There are used options and rebuilt options and even having your own battery rebuilt, which can be had for less than a new battery from Toyota. However, each carries different risks, and it is still not a cheap fix. A used battery from a salvage has unknown history and condition. A rebuilt battery is suspect, and I would recommend thorough research of the rebuilder. A straight dishonest rebuilder is unlikely, but someone who just made a mistake can't be ruled out. Rebuilding your own can be done with the right equipment cheaper than the other options, but requires technical knowledge, confidence, and research (although all the required information can be found here at Priuschat). Having your own rebuilt carries the same risks as buying one rebuilt.
    52,662
    what state are you in, is it carb?
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,450
    3,358
    Madison, Wisconsin
    Dillio,
    An independent shop should be able to do it for less than $3,000 using a quality rebuild from a reputable supplier.
    If your local mechanic needs some advice/direction feel free to have them give me a call.
    XT1049 ?
