2007 Prius Catalytic Converter for California. Where to get for best price?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by simple2code, Aug 4, 2017.
  1. simple2code
    simple2code New Member
    Rancho Cucamonga, CA
    Any leads where to get replacement catalytic converter for 2007 prius for California?
  2. johnjohnchu
    johnjohnchu Active Member
    211
    104
    I think catalytic converter is a dealer only item in CA. Need to install two new gaskets too. Parts will cost around $1.5K total. If the engine is burning lots of oil, then the newly installed catalytic converter probably will go bad again.
  3. JC91006
    16,500
    8,412
    How many miles are on your car?
  4. Daryl Tillman
    Daryl Tillman New Member
    Visalia Ca
    Three Touring
    I'm having the same issue. I have 233000 miles on my car.
  5. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Are you sure it's the CAT? I switched out the O2 sensors I ordered from A-zon (you know the website) and couldn't get rid of the codes. They were "OEM replacement parts" which I thought meant that they were Toyota OEM. (But they really weren't) I thought for sure it was the CAT that was bad. I was burning oil bad and thought the CAT was clogged. As a last ditch effort I decided to buy the O2 sensors from a Toyota dealership to make sure I used OEM Toyota parts, sure enough as soon as I used the Toyota O2 sensors codes never came back. Used CerTech Gels: Blowby with Engine Ceramics certech gel to stop my oil consumption. I didn't think it would work but it did. I also use createch (liqui moly) every oil change. https://www.amazon.com/gp/aw/d/B001CZODH8/ref=mp_s_a_1_5?ie=UTF8&qid=1503625720&sr=8-5&pi=AC_SX236_SY340_FMwebp_QL65&keywords=liqui-moly&dpPl=1&dpID=51WqU6%2B199L&ref=plSrch
    Hope you get your Prius working and back on the road.
    #5 Daves09prius, Aug 24, 2017
    emendia, Daryl Tillman and SFO like this.
  6. SFO
    SFO Senior Member
    5,297
    4,238
    Northern California
    Would be great if you started a thread talking about your use and success with Certech, pretty sure many here would be interested in knowing more.
    johnjohnchu likes this.
  7. Daryl Tillman
    Visalia Ca
    Three Touring
    What lights were coming on when you changed this? My check engine light outs on getting a code for cat. After driving local for 45 minutes or so my warning light comes on with vsc light as well as an light. A/c stops working. Let it sit for 15 minutes vsc and ab lights go off and warning light and check engine ask stay on. Could this be my inverter failing?
  8. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,484
    Bay Area, California
    2019 Prius Prime
    Your inverter pump has failed.
    An easy fix(y).
    SFO likes this.
  9. kayybrownie
    kayybrownie New Member
    Los Angeles
    Hi did you get any good leads? In the same predicament with my '04.... Dealer quoted me $2,500 just for the part. I'm seriously considering parting out the car if repair is seriously going to cost this much!
  10. JC91006
    16,500
    8,412
    Go to a private muffler shop and ask to get a catalytic converter welded on, it'll cost less than $300.
  11. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    This is almost right, sell your Prius out of CA (or NY) and this is legal in the other 48 states. Sadly, you will not pass inspection in CA with a noncompliant Cat, and for a Prius, only a Toyota Cat is compliant.
    17410-21500 - Toyota Parts Deal
  12. kayybrownie
    Los Angeles
    Thanks for the link! I've been looking for the part number
    It's also illegal to use a salvaged part right? Even if OEM?
  13. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Does that include a random aftermarket cat or you take it to them?
  14. JC91006
    16,500
    8,412
    After market cat is going for about $65 on Amazon. You'll just need to figure how to get it to California
  15. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Thanks for the hint.. I had to find a junk yard to give me one for "free" lol.
    SFO and Raytheeagle like this.
  16. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    There are no CARB compliant cat replacements for the 2nd gen Prius.
  17. JC91006
    16,500
    8,412
    That is correct
  18. Figster10
    Figster10 Member
    207
    61
    Sacramento
    If l can get an after market one here but indirectly will it still show that it’s California legal when it gets smog checked? I’m curious if I do order it and they snoop around will they just try to fail my smog because somehow they saw it was bought after market out of state?
  19. Raytheeagle
    11,251
    15,484
    2019 Prius Prime
    The short answer is they are “supposed” to check for identification on the cat.
    But some shops don’t bother;).
    The shop I go to in San Ramon didn’t check the last time and all that was checked was the gas cap and a quick perusal if te engine bay while the obd device was hooked up:).
    But you could check with @Joele3 and see what he knows(y).
    JC91006 likes this.
  20. JC91006
    16,500
    8,412
    Majority of the shops don't check under your car
    Raytheeagle likes this.
