2007 Prius Catalytic Converter (WA) Replacement Sounds Strange
Discussion in 'Gen 2 Prius Accessories & Modifications' started by LifetimeLearner, Feb 5, 2022.
  1. LifetimeLearner
    LifetimeLearner Junior Member
    nome alaska
    Cat converter stolen - replaced with moderate aftermarket part by very reliable mechanic - upon getting car back I can hear a faint noise similar to the sound of a vehicle in high gear. Is this a vibration I am hearing from the replaced parts? I also had a CAT Shield installed at the same time. Has anyone else noticed new noises with a replacement catalytic converter? I am told there is a "break-in" period which I do not understand either.
  2. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Likely the cat shield, not sure about the break in period, unless it was related to an odor issue.
    ydpplqbd likes this.
