2007 Prius - Check Engine, Red Triangle, VSC Lights - 12 volt battery issue?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Jan 30, 2018.
  1. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    In the office the first thing I would say is, "Is it plugged in? Is it turned on?" It is remarkable how many times that all it took to solve the problem.
    OP, your 10 year old battery is about as good as it gets. The only sources of reliable replacement batteries are through a dealer (new cells from Toyota), a used battery as tested by the member referenced earlier (not as good as new), and the kit with the new cells, also already mentioned.
    Just my opinion: Anyone else offering to replace cells or the entire battery on the cheap is doing so by scrounging whatever cells they can find on the market. If you want "cheap" and "fast" you won't get "good". If you are selling the car the day after the install then if it is just a matter of "don't ask, don't tell" then drop in the cheapest battery you can find that won't throw a code and we'll give the same advice to the next new member that posts "I just bought a 2007 and the dash lit up and the car lost power".
    Spend the money to buy a battery that can be expected to last at least a few years. It is cheaper than buying a newer car. Your 12v battery would benefit from a battery tender which is inexpensive.
    I wish you the best of luck whichever path you end up taking.
  2. tampaite
    tampaite Member
    237
    42
    FL
    I love this quote - "it's cheaper than buying a newer car"
    I get your point but when is a repair expensive than buying a newer car? NEVER. No repair is as expensive as a newer car. If so, we would all be repairing the same car and keeping them forever. Just kidding.
    I think with a 10+ year car, I have already spent $$$ replacing the inverter pump, engine pump or water pump, the 12v battery, serpentine belt all within the last 2-3 years and those have already added 3k+. Guess, I should have sold my Prius 2-3 year ago.
    I don't want to be spending more $ into a 10+ year old car and if someone were to buy a 2007 car, am sure they understand the risks.
  3. JC91006
    16,936
    8,647
    Diy on the prius is actually not hard and very inexpensive
    1. Water pump and belt $60
    2. Inverter pump $80
    3. 3 way coolant valve $80
    4. 12v battery $200
    5. Coolant $50
    So $500 would've done it with some basic tools and about 2 to 3 hours of your time
  4. tampaite
    tampaite Member
    237
    42
    FL
    Where were you when I need these to be worked upon ? :)
    I would have gladly paid you $500 while you spent 2-3 hours of your time working on my car when repairs are needed.
    Wish all these happened at the same time - they do happen over a period of time and having parts available, having the knowledge, lost time and wages and there is a whole lot of things other than just $$$.
    My attempt at using $$$ was that I didn't want to *sink* anymore money into the car than what's needed currently and for me that would be to extend the life for another 1-2 years or max 5 years.
  5. JC91006
    16,936
    8,647
    That is called diyourself
  6. tampaite
    tampaite Member
    237
    42
    FL
    well, lets take the case of Hybrid battery. Do you think I can DIY? how much would I be saving?
  7. JC91006
    16,936
    8,647
    Diy hv battery can range from $100 to $2000. Depending on the quality and longevity you are after.
    Yes I think anybody that can lift 80 pounds out of the car can do it
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    If your local Toyota dealer will sell you a Toyota hybrid battery at retail price it will hopefully be around $2,100.
    You'll have to call and see.
    If you know someone who has a business, perhaps they can get a lower price (wholesale) without paying tax, and you can buy it from him for less. You guys will have to work out the sales tax.
  9. ChapmanF
    19,017
    And so, like clockwork, we return to your contention that the reported information is likely to be wrong, and to the simple question, how likely do you think?
    And by "how likely", I mean, can you offer any substantiated example at all? We both know what that would take, and it should not be impossible, or even hard, if it happens as commonly as you suggest.
    A good substantiated example would be a significant contribution to PriusChat, and one you might be able to make.
    -Chap
    SFO likes this.
  10. tampaite
    tampaite Member
    237
    42
    FL
    why do installers require core in exchange? What's the value in it?
  11. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    They will get your 'core' which contains battery modules that are newer and or in a better state of health over what they're actually selling you.
    Better for them to have a not working set of factory matched modules of the same age (core) over a bunch of used mix matched modules from different vehicles (which is what you would be buying), then they can take your rebuildable 'core' pop one or more modules in it and sell it to the next guy. Rinse, Repeat, Profit.
    #91 SFO, Feb 1, 2018
    Raytheeagle and tampaite like this.
  12. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    That's not what I said at all.
    I said that it is POSSIBLE for it to be wrong if the 12 V system is out of spec.
    I also said that not checking the 12 V system first is just stupid.
    A lot of factors come into play in GUESSING how likely it is to be wrong.......and the whole point is to NOT GUESS but to test it and be sure.
    Your incessant and unproductive arguments are becoming tiresome.
    Give it a rest please.
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    The components can be recycled.
    I believe that there are laws requiring that to be done.
  14. tampaite
    tampaite Member
    237
    42
    FL
    No problem. Since you questioned, I reached out to Affordable Hybrid again and this time, they are telling me these are commercial modules and NOT Panasonic ones.
    I pressed as to what brand they were - no answer except to say that, they are slightly higher capacity and more durable.
    I don't like it they changed their story bu on the upside, they do offer free installation of replacement during the warranty period unlike others who require you to pay $250 or so to installed items replaced under warranty.
  15. JC91006
    16,936
    8,647
    Panasonic isn't the maker of the OEM modules, they were bought out many years ago. He could've given you any answer and you wouldn't have known better
    I don't believe this guy knows what he's selling
  16. tampaite
    tampaite Member
    237
    42
    FL
    so who makes them now?
  17. JC91006
    16,936
    8,647
    From 2010 PRIMEARTH EV ENERGY produced the modules. Which is kinda still Panasonic, but they have a small ownership
    #97 JC91006, Feb 1, 2018
    Raytheeagle likes this.
  18. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    If they are indeed new, they probably are sourced from China. Were they prismatic or cylindrical? Otherwise they are just recycled old modules. If they were from a new pack (towards 2015), that wouldn't necessarily be bad.
    I would hope that you keep pressing him to supply some documented evidence of these claims. They are easy to make, I wouldn't readily believe claims made by the manufacturer either, without further documentation of the testing regime.
    A member here, 2k1Toaster,, who has the equipment to test these things tested the capacity of a set of Chinese cylindrical modules (CEBA, I think) with a claimed 6500 mAh capacity and they came up well short, nearly only half of that capacity. This datapoint spearheaded the desire to do better and he has brought to market cylindrical modules with a true 6500 mAh capacity. He uses his own trusted manufacturers to make the modules.
    There are a number of suppliers in China that make prismatic knock offs and others that make cylindrical modules that all fit, but so far, no reputable builder will use them, because they are just not of good enough quality. Even so a set of these will cost $1300 by the time they are landed and all fees and taxes are paid.
    So, my caution is caveat emptor.
    #98 dolj, Feb 1, 2018
  19. tampaite
    tampaite Member
    237
    42
    FL
  20. JC91006
    16,936
    8,647
    A rebuilt battery is only as good as the person that's doing the rebuilding, they have all skill levels.
    Like the mechanics at your dealer, some are really bad and some are just a little bad
