2007 Prius : correct spark plug gap
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by suncitychris, Dec 3, 2024.
  1. suncitychris
    suncitychris Junior Member
    El Paso Texas
    I have a 2007 Toyota Prius Service Manual; the Manual states the spark plug gap is 0.7 to 0.8 mm (0.028 to 0.032 in.) Numerous threads have posted a spark plug gap of 1.0 to 1.1 mm. Did Toyota issue a technical bulletin with this change? Which gap parameters are correct? Thanks so much. IMG_4344.jpeg IMG_4345.jpeg IMG_4344.jpeg IMG_4345.jpeg
  2. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    That is interesting. Is that part of the diagnostic procedure for P03xx codes?
    I see that same illustration there in my copy of the manual.
    There are two other places where they show or state 1.0 mm - 1.1 mm.
  3. suncitychris
    El Paso Texas
    Yes, that is correct. What effect might one see if the spark plug gap is reduced from 1.0mm to 0.8mm? Thanks so much for the input.
  4. dolj
    dolj Senior Member
    8,559
    4,349
    I don't know, but my feeling is that it would not be a good thing to do.
    Have you considered the possibility that the section of the manual you're looking at is incorrect?
    The plugs are factory-set at 1.1 mm, and I have never had to adjust them, ever. I just check each plug before installing and have never had any problems engine-wise.
  5. Mendel Leisk
    41,925
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,094
    1,997
    NJ-USA
    I might expect a slight possibility of occasional misfire under some limited conditions.
    Probably won't affect anything.
  7. suncitychris
    El Paso Texas
    Gentlemen: thank you for the feedback, it is acknowledged and understood. Appreciate you all!!
