2007 Prius Displaying P0A93 P0016 C1300 C1242 C1241
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by fornnwet, Aug 10, 2019.
  1. fornnwet
    fornnwet Junior Member
    Seattle, WA
    I'm the original owner of a 2007 Prius with ~115k miles on it. It's never given me any mechanical issues before tonight. I was driving to dinner when the red !, yellow !, check engine, and VSC lights all came on at once. A red ! icon also displayed at the top of my touchscreen. A moment later the parking brake and ABS lights also came on, and it started emitting a constant tone. I pulled over to the shoulder and turned it off for a moment, then turned it back on and the brake lights were off.
    I drove it the final mile to my friend's house, where I let it sit for several hours before checking on it again. Only the red ! and check engine lights were now on, so I drove it to the nearest auto parts store to pull the engine codes. They are:
    • P0A93 Inverter A Cooling System Performance
    • P0016 Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A
    • C1300 Malfunction In Engine Control Unit
    • C1242 Open Circuit In IG2 Circuit
    • C1241 Low Battery Positive Voltage Or Abnormally High Battery Positive Voltage
    I plan to take the car into the dealership to have it checked out by the experts, but I'm hoping to get an idea of what I might be in for so I can mentally prepare for what to expect (and weigh whether or not it's worth any drastic efforts to save a car only worth ~$2k KBB).
    Thanks for any insight you can offer, fine community!
  2. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    2004 , 160k mi, had same invertor pump code about 15k mi ago.
    p do not drive long distances with that code if the pump is not working you can see if the coolant is moving or sometimes hear it move if you have to drive long distances put a bag of ice on top of the inverter.
    dealer wanted 700 my brother changed it about an hour ... online purchase of pump, about a hundred and fifty bucks. see videos...
    just today, check engine light came on and my scan threw the three same open circuit codes, so appreciate any advice too
  3. dolj
    dolj Senior Member
    8,202
    4,178
    Wellington, New Zealand
    Replace the inverter coolant pump (with a new OEM ICP) and then clear all codes. See what codes comes back. Deal with any other codes then.
  4. waqar`
    waqar` Junior Member
    UK
    is there an update on your situation. I have the same issue st my end.
