2007 Prius Fuse/relay location
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bill Brannigan, Sep 17, 2016.
  1. Patrick Wong
    18,210
    6,511
    The red relay is IG1.
    The blue relay is HTR.
    The large grey relay is the flasher relay.
  2. Bill Brannigan
    Bill Brannigan New Member
    Kennewick, Wa
    I
    Patrick, how difficult is it to trace for a bad ground in this circuit.
  3. Patrick Wong
    18,210
    6,511
    Easy. Use an ohmmeter to measure resistance to ground. Get the wiring diagram at techinfo.toyota.com
  4. Bill Brannigan
    Kennewick, Wa
    I
    Ok, after a lot of replacing the fam motor and blower control motor I took my 2007 Prius into Toyota. The service guy need 2 hr to track down the problem. This is the rest of the story. The figure of $4758.43 is crazy..... IMG_9118.JPG IMG_9118.JPG IMG_9118.JPG
  5. Patrick Wong
    18,210
    6,511
    I suggest you buy a used AC amplifier and replace it yourself.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    My motor started not starting intermittently. After 3 times bought new motor
    Online.
    Have not seen the controller go bad. If me i would have installed new motor
    First. Used motors are just that.
    Try new motor first.
  7. Bill Brannigan
    Kennewick, Wa
    I
    Patrick, they said it would take 10 hours to replace the AC control Module. The thing is it's a second car that my wife just uses around town. If I had a way to just clear the front window using a separate defroster that would work. Just think of a person paying 5K to get heat and AC in the car. Toyota is saying there is a lot that has to come out of the car in order to replace this part.
  8. Patrick Wong
    18,210
    6,511
    Well, the AC amplifier is located behind the center trim panel which runs from the hump on the floor up to the instrument panel, below the radio controls. I doubt that 10 hours of labor actually are required for access and replacement, however I have not needed to do that work. Since that panel is plastic you might be able to yank it out with less disassembly than indicated by the repair manual which assumes you are removing the entire dashboard...
    eBay carries used units for $50 or so.
    prius air conditioner amplifier | eBay
    I guess you'll have to decide whether it is worth $500 / hour for you to DIY. I am not in a profession that pays me at that rate, so I personally would make a strong effort to DIY or find another alternative to the Toyota dealer. Consult techinfo.toyota.com for repair manual info.
    SFO likes this.
  9. JoeVR
    JoeVR Junior Member
    23
    Midwest
    I wanted to resurrect this thread - does anyone have any directions or support on how to disassemble the center trim panel to access/replace this AC amplifier?
    Thank you so much!
  10. edthefox5
    10,096
    4,834
    Clearwater, Florida
    There’s lots of posts in the search forum about the ac amplifier.
    use the search forum link up top and search
    ac amplifier
