2007 Prius gas pedal issues
Discussion in 'Newbie Forum' started by Freebird, Mar 2, 2018.
  1. Freebird
    Freebird New Member
    28
    Hello,
    I bought a 2007 Prius this January, and for the most part I'm very happy with the car, but there's one issue that is starting to be a problem for me. Compared to my old car (a 1992 Honda Accord) the gas pedal is not very sensitive and I have to push down HARD if I want the car to go more than 40 MPH.
    A little background – I have a disability that makes it very difficult for me to do anything strenuous with my arms. I can push all the buttons in the car as long as I don't push too many in a short space of time. But this also means it hurts me to use my arms to control the mouse on my computer for any length of time. So for the past couple of years, I've been controlling the mouse with my right foot (using a program called Dwell Clicker to do the actual clicking). Until I bought the Prius, this setup worked very well for me and I could spend hours on the computer every day without pain.
    But after a few weeks of driving the Prius – in particular, after one long drive in February – I noticed that my right leg was starting to have a lot of pain. Especially on days when I drove the car and used the computer right after coming home. The problem got so bad that I had to completely stop using my foot to control the mouse. Currently, I'm only using my arms to move the mouse, which means I have had to drastically cut down on my computer time.
    I've tried moving the car seat closer to the pedals, and that has helped a little. I also make a point of using a series of gentle pushes to get the car up to speed, rather than one big shove. But driving still hurts my leg, and now I'm actually afraid to take the car on any long drives. I have considered the cruise control, but local traffic is very heavy these days so it's not practical for all that stop-and-start driving.
    Is there anything else I can do – or a good mechanic could do – to make the gas pedal more responsive? I thought about putting in some STP gas additive, or even some fuel injection cleaner. Would that help at all? I'm also wondering if the recent cold weather has made the problem worse. My MPG has also ticked down a bit since the cold weather started.
    If I can't find a way to make this better, I may have to get rid of the car. It's that serious, so I'm very much hoping somebody out there will have some advice or suggestions!
    Thank you for reading.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Have you tried the "B" mode?
    It's like a lower gear for long downhills, it may help in stop and go traffic.
  3. Freebird
    Freebird New Member
    28
    My understanding of the B mode is that it should only be used when going down hill, and shouldn't be employed for long periods of time. It's also my understanding that it slows down the car, which is the opposite of what I need. I'm desperately hoping there is some way to make the car go faster more easily, so I don't have to press down so hard on the gas pedal when I want to go fast.
    But thank you for reading and trying to help. I really appreciate that.
  4. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I'm not familiar with your model of Prius @Freebird , but if it has a Mode selector button somewhere this could resolve your problem. It sounds like you may be in ECO Mode which gives the gas pedal a very relaxed response till you floor it. You'll need to press the Mode button and it should change to Normal mode, where the gas pedal is more like you'd get in a conventional car. Press again for Power mode to get a very sensitive gas pedal response, it's too sensitive for many people, but may be just what you're looking for. I hope this simple solution does the trick for you, but don't despair. Somebody smarter than me will sort you out on here eventually.
    Freebird likes this.
  5. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    I don't think that a mode selector switch was on the Prius until the 2010 model. The pedal on the Prius is an electronic speed control and has no mechanical connection to the engine (plug-and-play.) Do you floor the pedal when accelerating? (It is OK to do so.) If you do and the car is still not responding as quickly as you need it to, then the car is under-powered for your needs. There isn't any way to make the engine larger. The car may not be suited to your needs.
    Also, have you looked into the Wahls' Protocol by Dr. Terri Wahls to possibly help with your pain issues? It's worth a look at her book to see if it could possibly help with your symptoms. I am not a doctor, but it has helped my wife tremendously.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    I'm not familiar with the book @Bill the Engineer mentioned, but I do think it's more likely that it's more of a progression (degression?) of your condition or disease. I would ask my doctor for suggestions.
    When you say "press down HARD," do you actually mean "farther?" The Prius throttle spring is very gentle, imho, but it's fairly long travel. There are no mode selectors in the Gen 2 version of the Prius. If you had a 2010 or newer, you could try power mode, which would give more engine response for the same amount of pedal travel. It also just has more power to start with than the Gen 2. B mode has no effect on throttle mapping, though, so you're right about that.
    Another difference is in the seat height. Gen 2 has a higher seat than Gen 3, which changes the angle of your ankle. Maybe a thin block on top of the pedal would improve that angle. You'd want to make sure it was very well secured so it couldn't come off and interfere with gas or brake operations. And I haven't checked on the legality of doing that, but I think I once heard of kits that do that for people with especially short legs.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    Some questions:
    • How many miles on your 07?
    • How many miles do you put on your Prius and in what period of time?
    • Have you ever had any issues with the hv battery?
    • How fast do the bars cycle on the battery display?
    We have one member here who is an entrepreneur that works on pedals: @Pedal Logic :).
    He has owned a Gen2 and currently has a Gen3 and a v wagon;).
    Marc will be along and might have some insight(y).
  8. Pedal Logic
    Pedal Logic Active Member
    163
    175
    Hi Freebird,
    Despite the detail of your explanation, I'm not entirely clear if the issue is the rate of acceleration or the distance moving your leg. If the former, there's really not much you can do to improve the Prius absent extraordinary measures. Possibly an EV with suitable range might be a good candidate for your needs?
    [Am I committing some sort of unwritten sacrilege on the forum by recommending another type of vehicle???]
    If it's instead a biomechanical issue — the distance your foot needs to travel — there are products (usually made in China) that can modify the pedal signal to increase the rate of demand. Most of those products only support the 2010+ Prius, though. I'm also not sure that you would really see any meaningful improvement in the Prius acceleration rate due to it's tiny motor(s).
    I wish I had better news to report.
    Marc
    #8 Pedal Logic, Mar 3, 2018
  9. Freebird
    Freebird New Member
    28
    I have looked through the owner's manual, and I have seen nothing anywhere about the different modes you mentioned. So I'm pretty sure that must've been a later model. But that sounds like an awesome feature which probably would have completely solved my problem. Thank you anyway.
    RCO likes this.
  10. Freebird
    Freebird New Member
    28
    Scroll
    I prefer not to floor it, as you say, because that is what hurts my leg the most. I did at first. I suspect you may be right… It just feels like the car doesn't want to go very fast, at least not compared to my old Honda. Maybe that's a function of the low horsepower. I was just hoping there was some way to make the gas pedal a little more sensitive. I think I read somewhere it's called throttle response.
    Thank you for the pain recommendations. I didn't want to spend a lot of time going into the details of my disability, but I have a severe case of Repetitive Strain Injury. I injured my arms through years of overuse, and now I have injured my right leg. To be fair, the Prius is only part of the reason my right leg is compromised. In any case, the cure is rest. If I can go a few days without straining my leg, it feels much better. But of course, it strains my leg every time I drive, and the Prius wants to be driven on a regular basis.
    RCO likes this.
  11. Freebird
    Freebird New Member
    28
    Thank you for the advice. As I just mentioned above, my condition is not a disease and not necessarily progressive. The key is rest. But my arms are so messed up it will take at least a year of good rest for any hope of recovery.
    When I say I pressed down HARD, I do mean farther but it also means I have to push down with a lot of pressure. You are correct that part of the problem is I have short legs. The problem has gotten noticeably better since I moved the seat closer to the pedals. I didn't know that about the seat height in Generation 2s being unusually high – I'll look into ways to compensate for that.
    It does sound like a 2010 or later model would be perfect for me. I've also heard that later model Prii have a special kind of cruise control where you can tell the computer how much distance you want between your car in the car in front of you, which means I could use cruise control in regular traffic.
    jerrymildred likes this.
  12. Freebird
    Freebird New Member
    28
    To answer your questions – my car has 98,000 miles and change. I have owned it for a little over a month, and in that time I think I've put maybe 300 miles on the car. No, so far no issues with the HV battery. When I got the car, I made a point of learning what to look for with regards to a failing battery, since I still have the original HV battery. My MPG has gone down slightly in the past couple of weeks. I was consistently getting 49-50 MPG on the first tank of gas, and now it is consistently 47-48 MPG. But we've recently had a snap of unusually cold weather, and I have read that can affect the MPG.
    I don't understand your question about how fast the bar cycles on the battery display. I usually keep it on the consumption screen, but I'll check the battery SOC at least once each trip. It's usually at six blue bars or better. Once it went down to two purple bars, but that was after a drive in very heavy traffic when it was very hot and I was running the AC.
    I hope that helps! Thanks for the reply.
    Data Daedalus likes this.
  13. Freebird
    Freebird New Member
    28
    I wish I could explain it better myself. All I can tell you is that I have to exert a lot of pressure with my leg to make the car go fast. Probably a big part of the problem is my legs are short, and as I mentioned in another reply, the problem has gotten somewhat better from moving the seat closer to the pedals. Instead of my calf muscles being sore after a drive, now it's my thigh muscles. But it just feels like this car doesn't have a lot of "pep" – at least not compared to other cars I have driven.
    I want very much to go on some long road trips eventually, so any car I buy would need to have a long range. Money is an issue, so I'm not enthusiastic to say the least about the prospect of having to buy another car. But if that's what I have to do to be able to drive without pain, I guess that's it.
    So I take it there would be no benefit to adding a gas additive like STP or a fuel injection cleaner? The first time I fueled up, I bought a high octane fuel, but more recently I filled the tank with regular 87 octane. Between that and the cold weather, I'm thinking it may have made the engine a little less powerful. Or is that my imagination?
    Thank you for the reply.
  14. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Sounds like you have most your 2007s Prius functions well understood.
    I had to double check when Power Mode was introduced,
    because that was my first thought to help in your situation.
    Unfortunately power mode was not available until 2010.
    My only other thought is to raise the driver seat and steering wheel as high as possible
    while keeping the seat as close to the steering wheel as you can safely have it.
    I'd also try using a cushion on top of the seat to raise you up even higher.
    Then instead of thinking of pushing the gas pedal forward,
    rather think of more pushing the pedal down from above it.
    This is similar to the way a big truck is driven. Very old ( before my time ) delivery trucks were driven with the driver standing up.
    guessing it might be worth a shot ...
    ps just curious if you like any of the classic Southern Rock Bands
    #14 vvillovv, Mar 3, 2018
    RCO and Freebird like this.
  15. bisco
    52,912
    a number of healthy people have reported right leg pain due to the prius seats. make sure that isn't part of the problem before investing in other solutions.
    RCO, Freebird and vvillovv like this.
  16. Freebird
    Freebird New Member
    28
    Thanks for the suggestions! At this point, anything is worth a shot.
    To answer your question… I'm a fan of Lynyrd Skynyrd. My memory is pretty fuzzy on the names of any of the other famous southern bands from that era, but I'm huge fan of oldies in general.
  17. Freebird
    Freebird New Member
    28
    Thank you for the reply, but I'm a little bit confused. What specifically about the driver's seat in the Prius causes these leg problems? That it's too high, too low, or too something else?
  18. jerrymildred
    11,517
    14,171
    Tampa, FL
    That's probably because it doesn't have a lot of pep compared to most others. It wasn't designed for pep; it was designed for low emissions and high economy. Gen 3 is considerably stronger, plus it introduces the "power" mode. Power mode doesn't make it more powerful, it just opens the throttle farther in the early stages of pressing the pedal, so you don't have to press as far unless you need full power.
    I'm surprised no one has mentioned cruise control other than your wish for the dynamic radar cruise control offered on the high end Gen 3 & 4 models. I use my "dumb" cruise control even in moderately heavy traffic. It's then a simple matter of using the little lever to modulate speed or to disengage it.
  19. vvillovv
    4,337
    1,519
    NY
    @Freebird I was going to ask what other cars or trucks you've driven.
    The only way anyone would be used to Prius acceleration would be if they had driven another hybrid
    before getting in a Prius. As far as I know all hybrids sold commercially prior to around 2012 or so
    were a bit slow out of the chute. And that's probably an understatement .....
    A few other classic Southern Rock Bands include Charlie Daniels, Allman Brothers, Elvin Bishop, . Marshal Tucker etc
    and a couple lesser known hit makers 38 Special, Wet Willie
    Sweet Home ;)
    I was going to include something very similar in my post. But when I started writing the way it looked to me just didn't seem to express what I wanted to say, so I decided not to include it.
    And your description looks as good as it gets, much better than what I could have produced. :)
    Since you use cruise in your PIP do you know or can you test to see if you have this cruise feature? bug? with your cruise stick.
    When cruise is on and holding the cruise stick down for 5 seconds, do you get an extreme slowing effect, much faster deceleration
    than normal cruise deceleration, like I get in the Prime?
    jerrymildred and Freebird like this.
  20. bisco
    52,912
    i can't answer specifically what causes the leg pain unfortunately. people try all kinds of remedies from bolsters on the side of their leg, to lumbar supports, to swapping out seats, to trading the car.
