2007 Prius. Hybrid battery (original) failing...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Danica, Aug 6, 2025.
  1. Danica
    Danica Junior Member
    31
    Thank you for the response. To answer your question, no I do not have a dog. I have a couple cats, but they never ride in the car unless they are going to the vet, and then they are in a carrier up front with me.
    Yes, the summers here can be brutal. I've been trying my best to protect the car from the summer heat ever since I bought this Prius in 2017. I try to do all my driving in the early mornings, unless I absolutely have to go somewhere in the middle of the day. I keep the car garaged, with all the windows open. And I seek out shady parking spaces whenever possible, and put a reflector in the windshield. Until yesterday, the car had seemed to be doing well.
    The dealer I spoke with said that as long as the car still has the original core I will not be charged. I got an estimate in writing, and it contains an instant rebate for the core, as long as it is original. I bought the car used in 2017 (from a dealer) and was told it was still on the original hybrid battery. I also got a printout of all the mechanical work the previous owner had done on the car, and there was nothing in there about the hybrid battery being replaced. I remember being told that the previous owner was the same person who had bought the car new, which I believe was confirmed in the printout.
    The car might be drivable in the early morning, the coolest part of the day here. But after what happened Wednesday, I'm afraid to risk it. If the car flaked out on me while I was driving on a busy street, or worse, in the middle of a busy intersection, that could be dangerous. I'd rather pay for the tow than take that risk.
    Thanks again.
  2. Hayslayer
    Hayslayer Active Member
    390
    219
    You are making a wise choice. The only other thing that may come up at the dealer is the battery computer. The gen 2 hybrid battery has an ecu module inside. The voltage sensing wires connect to that ecu. Sometimes, there is significant corrosion on the ecu pins where those wires plug into. It's unfortunate, but it happens. If it's severe enough, it will cause battery faults and can even cause a high voltage short circuit and start a fire at the ecu connector. The new batteries do not include the electronics section of the battery, which includes the ecu and relays and a bit of wiring. Those original parts are transferred to the new assembly. IF IF IF your ecu has corrosion, they will likely tell you a new ecu is needed. These are about $1000 new from Toyota, about $100-150 for good used ones on ebay. Even I keep several in the shop.
    You could also call Greenbean and ask them what style battery modules are used in their "new module" packs. If it isn't new Toyota/Panasonic/PrimeEarth prismatic modules, I would stay away. Now, if it is Toyota/Panasonic/Primeearth prismatic modules, the good thing about Greenbean is they show up at your door with a COMPLETE battery, with the ECU fully inspected and repaired if needed, so there's no tow required and no surprise $1000 ecu charge there.
    Although Toyota doesn't sell these modules separately from a battery assembly, for DIYer's it is possible to buy a less expensive battery for a different model car and install those modules into a different case, for a different car. The same modules are used in dozens of car models. For example, I can buy a battery for a gen 3 for about $1500, and put those new modules in a Gen 2 pack.
    You will have no "must drive every day" problems with a new Toyota pack. When new, these packs can sit in a car for a year or more without being used and they will be perfectly fine. The 12v battery will be dead, but the HV battery will be fine. They don't start having self-discharge problems until several years of use. Based on your usage description, that will work great for you.
    Danica likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,590
    768
    Southern California
    One can always ask. Since they make a big fuss about new cells, but say nothing about what they are on their web site, it seems super unlikely that they have access to the same modules that Toyota uses. They might have modules that look like, and are spec'd like Toyota's, but that doesn't mean they will actually last as long. (Just like all "AA" alkaline batteries look about the same, doesn't mean they have the same longevity or capacity, far from it in fact.)
    Danica likes this.
  4. Hayslayer
    390
    219
    You nailed that and I agree 100%. That's why I had this statement about manufacturers: If it isn't new Toyota/Panasonic/PrimeEarth prismatic modules, I would stay away.
    Panasonic was the original manufacturer of the prismatics used in Toyota hybrid batteries. Not remembering all the details, but they later split off the battery division into some partnership with Toyota, iirc, and renamed it PrimeEarth.
    I've seen Chinese "prismatics" online a few times over the last couple years. They probably work as well as their "Denso" imitation sparkplugs....
    Danica likes this.
  5. Tombukt2
    Tombukt2 Senior Member
    12,908
    2,318
    Durham NC
    If you on phone price will no be correct . On line only pick up at store .
  6. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    Danica likes this.
  7. Danica
    31
    They sent me an email, with the price in writing. So I think I'm OK on that front. But I appreciate the warning.
  8. Tombukt2
    12,908
    2,318
    Durham NC
    Usually if you're walking into the parts department or talking to said parts department on the telephone you're not getting the best price. What you have there is is very decent I wouldn't waste time squabbling over maybe 200 . At best i paid like 1920 cash n carry at Fred anderson Toyoda. I took all stuff off old battery n prepped for turn in.
    Danica likes this.
  9. Danica
    31
  10. Danica
    31
    Well, I asked them to send me an email with the price of the battery in writing, which they did, so I'm not sure what else I can do. I agree that it's not worth squabbling over $200 or so. Unfortunately, I live in an area where I don't have a lot of options if I want a new OEM Toyota battery, which I have decided I do.
    Unlike most of you all here, I am just a layperson without much of a mechanical background. I'm in awe of the in-depth knowledge some of you have.
    This may sound crazy given that my hybrid battery is 18 years old, but I was not prepared for this to happen right now. When I bought the Prius, I read somewhere that your MPG will noticeably decrease when the hybrid battery is starting to fail, so I thought I would have some kind of warning. That didn't happen. So this situation caught me off-guard.
  11. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    I think the hot climate made it happen quickly. Also may be corrosion and clogged fan (if it is ) is a factor.
    Danica likes this.
  12. Danica
    31
    Definitely the hot climate is a factor. This happened on one of the hottest days of the year.
    For the past eight years I've been trying my best to protect my Prius from the summer heat, but there is only so much one can do.
    I will ask about the fan.
  13. PriusTech
    PriusTech Active Member
    247
    105
    Reno
    My 2005 went dead after 15 years and 80,000 miles, I think your's was a little above average.
    Maybe look for a hybrid specific repair shop and see what they charge to swap the new battery modules out of this case. The case is not for your car, but the new cells are the same. This is about a 2 to 3 hr job for a competent tech.
    https://toyotaparts.toyotaofelcajon.com/oem-parts/toyota-battery-assembly-g951047063
    Danica likes this.
  14. PriusTech
    247
    105
    Reno
    This is the Toyota part number. G9510-47063, look for a dealer close to you.
    A generic repair shop is probably not going to want to do this swap. You need someone that advertises hybrid repair
    Danica likes this.
  15. pasadena_commut
    2,590
    768
    Southern California
    Danica likes this.
  16. Danica
    31
    I just want to thank everyone for their kind advice. You all really helped me sort through all my options.
    Since the mileage on my car is still only around 130K, and reliability is very important to me, I have opted for a brand-new OEM battery from Toyota. My local Toyota dealership says they can put a new hybrid battery in my car for just about $3,500 even, including the installation. Spending a little extra money is worth it to me for the extra peace of mind. I hope to keep this car for at least another 5 years, and hopefully even longer. A spot opened up today and they are putting in the new battery right now.
    Thanks again!
    Brian1954, saneesh8 and PriusTech like this.
  17. Tombukt2
    12,908
    2,318
    Durham NC
    I work on a local car with 425k on original we get into 100 here
  18. saneesh8
    saneesh8 Member
    184
    46
    Allen, TX
    425k on original battery? what other stuff you had to replace?
  19. Danica
    31
    UPDATE:
    To refresh: My 2007 Prius crapped out on me last Wednesday while I was driving on a very hot day. I had the car towed to my local mechanic, who doesn't do hybrid work, but he said he would be happy to run a diagnostic for me. This mechanic told me the diagnostic registered a large power drop-off, and he said since the 12V battery was fine, it must be the hybrid system.
    He also told me he had gotten the code P3011 from my car and the dashboard said, "check hybrid system." The hybrid battery is 18 years old, so I just figured it had finally given up the ghost.
    So I had the car towed to the dealership so they could replace the old hybrid battery with a new OEM Toyota battery. I hadn't heard back from them yet, so gave them a call this morning.
    The guy in the service department said that the 12V battery has gone bad, and that at least so far they can find nothing wrong with the hybrid battery. The car is not throwing any codes. He said that a bad 12V battery could explain the P3011 code.
    I authorized them to replace the 12V battery. They ain't cheap,but neither is having the car towed yet again.
    After they put in the new 12V, somebody from the shop is going to drive the car around for about 30 minutes (it's very hot again today) to see if any problems crop up. If not, apparently the hybrid battery is OK after all, and I'm just out a few hundred dollars for the second tow and an expensive 12V.
    If they tell me I still need a new hybrid battery after all this, I may consider other options.
    Either way, I think I need to look for a new local mechanic.
  20. pasadena_commut
    2,590
    768
    Southern California
    Bullet dodged, maybe. If that is the OEM HV pack it is still living on borrowed time. Frankly it would be amazing that it lasted this long given the extreme high temperatures in your area.
    Danica likes this.
