2007 Prius Inside Fuse Box
Discussion in 'Gen 2 Prius Technical Discussion' started by Waisit, May 16, 2019.
  1. Waisit
    Waisit New Member
    San Francisco, CA
    Do I need to pull off any panels to access the inside fuse box?
    Does anyone know if the remoteless entry also has a separate fuse in the same place as the cigarette lighter?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your owners manual has the answers you are looking for.
    SFO likes this.
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    #3 SFO, May 16, 2019
    Skibob likes this.
  4. JC91006
    16,936
    8,646
    Keyless entry has a button under the steering wheel that turns it on and off. It's marked SKS.
    If that doesn't fix your problem, your car may not have the option or the keyfob is not programmed properly
  5. Skibob
    2,912
    1,505
    Northern California
    Very noble but if the OP can figure out how to post here he should be able to use your most helpful link. ;)
