2007 Prius Is Dead
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Shel, Oct 22, 2021.
  1. Shel
    Shel Junior Member
    This morning, sweetie tried to start her Prius and the car was dead. I'm thinking it might be the starting battery that's dead. However, we've had a weird recent history with the car. A couple of weeks ago I was backing it out of the garage and the engine kept dying. After a bit, I got it to run, took it for a short drive, and all seemed to be well. Took the car to the local tech for a thorough exam, got a clean bill of health, and the car was fine until yesterday afternoon.
    Yesterday, the car was moved from the garage for a few hours, and then, when started to put it back in the garage, the engine would run for a brief moment and then die, just as it did two weeks ago. Eventually, the car got into the garage where it sat until a short while ago. Sweetie tried to start it and the car was dead. However, the light inside the car that goes on when the doors are opened worked. After a bit, it too died ... now the car is like a corpse. No lights, can't get the engine to react to the key or start button.
    The battery, BTW, is relatively new ... about two years old. I don't want to just buy a new battery as it seems that there's an underlying issue. Any thoughts on what to check, what to ask a repair shop to look for? Give me an old slant six and I'm good, but I'm out of my element with the Prius, Thanks!
    Just checked and discovered that I can't open the hatch nor any of the doors other than the drivers door.
    52,849
    do u know the drill for opening the hatch?
    check the 12v connections, especially negative to body ground for corrosion and tightness.
    you can get a free 12v load test at most auto parts stores. many peoples 12 volts are dying due to covid, and less frequent driving
    SFO likes this.
