2007 Prius istrument cluster and MFD Not Working
Discussion in 'Gen 2 Prius Main Forum' started by Alan Sailer, Mar 21, 2023.
  1. Alan Sailer
    Alan Sailer Junior Member
    37
    I have a new to me 2007 Prius with 60K. Today the instrument cluster is blank and the MFD is not displaying data. The MFD is on but no mileage etc data is shown.
    In addition, I can exit the car with the key remaining in and no alert sounds.
    I know on my old Prius the instrument cluster went out because of a bad capacitor. Is this the same problem?
    Cheers.
  2. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    L82thePRTY and bisco like this.
  3. Alan Sailer
    37
    The MFD is working it's just not displaying new data ie milage etc
  4. Tombukt2
    Tombukt2 Senior Member
    13,827
    2,510
    Durham NC
    Usually when it's not displaying the data and the miles per gallon and whatnot the display is usually out so you have a display and no updated mileage or MPG on the MFD Is this correct?
  5. Tombukt2
    13,827
    2,510
    Durham NC
    By display I mean your heads up thing that you look at for speed your gas gauge and that sort of thing usually this is out and you get blanks in the MFD where the miles per gallon is displayed and the total miles on the car on the MSD either go blank or they stop where they were I can't remember they may be showing something but they haven't updated since the display went out.
  6. Alan Sailer
    37
    Tombukt2,
    Yes this is what is happening.
    I am still open to answers but I may have found the issue. The 12V battery voltage is only 12V unloaded.
    Since a lead acid should be at least 12.4V this might be it. I will change the battery and see.
    Cheers.
  7. Tombukt2
    13,827
    2,510
    Durham NC
    Well that will certainly be interesting because no matter what I've done with the voltage at the battery anyway the display problems I had were really strange I'm talking about for the mileage and gas and what have you But anyway it'll be interesting to find out.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Yes, you have another cluster that won't turn on, almost certainly due to a bad capacitor.
  9. highmilesgarage
    highmilesgarage Active Member
    494
    183
    Kansas City
    I highly doubt its the 12v batter, if the car starts then it's not the battery. It will even work if it's 11.5v, 12.4v is when it's fully charged. As what @mr_guy_mann posted, it's the capacitor, sometimes the car will not power off if you have this issue.
  10. Alan Sailer
    37
    At least for now the battery appears to be the issue. I put another newer battery in and everything is working normally.
    I really have to find a better answer to the 12 volt battery issue. On my first 2007 Prius the original battery lasted for almost 10 years. Then replacement batteries seemed to last less and less for total of four over 15 years.
  11. bisco
    52,804
    oem's?
    could it be that you're driving less?
    there again, if this one is new to you, your old one might have been drawing too much when off
  12. highmilesgarage
    494
    183
    Kansas City
    tricky part about the capacitor issue is that disconnecting the battery fixes it temporarily.. for how long depends.. In my case it took like over 6 months before it went completely dead (just disconnecting battery everytime)
    what kind of battery you have AGM? AGM will definitely last for over 5yrs, OEM probably will last even longer. My Camry Hybrid Panasonic 12v battery lasted 15yrs, while on bmw 530i lasted 8years. Walmart and Auto Parts store batteries last for 3-5yrs, but you could be lucky if it last for over 5yrs.
