2007 Prius JDM extra Key(Keyfob)
Discussion in 'Gen 2 Prius Main Forum' started by Grundignz, Jan 28, 2018.
  1. Grundignz
    Grundignz Junior Member
    25
    Wellington, New Zealand
    I have just purchased a 2007 JDM (NHW20-3329680)display all Japanese it only came with one key this is the non SKS model(black toyota symbol). I have read all the forums about adding another key easy enough.
    My question is my local wrecker(some call salvage yard) has a NZ new 2008 Prius will one of the keys from this work with my car??
    Also would it work if i purchased a ebay(US) key??
    I read somewhere that the keys(keyfobs) have different frequency's for different regions
    Thanks
    David
  2. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    For the simple programming method to work you do need a new unused keyfob.
    I tried to look it up from Toyodiy and that gives different part numbers for JDM than other regions. So you probably do need a new key from Japan. Australian model seems to have the same key as European models. Is the New Zealand model same as Australian?
  3. Grundignz
    25
    Yes it seems Australia and New Zealand same specs.
    I read the articles and its not to difficult to make remote Virgin again
  4. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    Would be great if you could post the process for taking a used FOB and making it 'virgin again'.
  5. Grundignz
    25
    I was just following the youtube video on key reset
  6. valde3
    2,002
    751
    Finland
    Do you have that wireless programming tool?
