2007 Prius knocking noise, rattle.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Drakemyers, Oct 26, 2015.
  1. Drakemyers
    Drakemyers New Member
    Illinois
    My car is making this noise. Its only at idle. Doesnt affect fuel economy, just alarming. Thanks for all replies and help.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    Sounds like valve lifter noise to me.
  3. JC91006
    16,937
    8,647
    I have the exact same noise on my 2006, burns oil but runs strong. Had that sound since I bought it 35k miles ago, never broke down, even on long distance trips
    #3 JC91006, Oct 26, 2015
  4. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Valve ticking. My 2004 Honda Accord did it for 50k miles with no ill effects (that I am aware of).
    Many possible causes and solutions, but it is something that CAN have a serious enough cause that I would get it professionally diagnosed, if I were you and I didn't have a whole lot of mechanical knowledge (if you do have the mechanical wherewithal to diagnose yourself, feel free). Some engines just have a tendency to tick over time and are generally not a problem. With the little I know of Toyota and the Prius ICE, I can't say whether or not the Prius falls into that category, but perhaps some other, more knowledgeable members can help out.
  5. bisco
    52,876
    maybe try synthetic oil?
  6. JC91006
    16,937
    8,647
    Synthetic oil doesn't fix it, I'm not certain it's valves, someone was telling me it's the vvti system in the engine. There's a write up on adjusting valves, but it's easier just replacing the engine
  7. bisco
    52,876
    how many miles on her?
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I hear some thumping in there in addition to the solid lifter racket. Alot of posters post about top end noise and alot find out they have the beginnings of a spun main bearing. Put the car in inspection mode (youtube: Prius Inspection Mode) and then while its running get under engine and listen with a rod to your ear to the oil pan and see if you can hear some banging in there. Seen alot of them here lately.
    Maybe just listening to the engine underneath will tell you the story.
    Then change the oil and drain the oil into a nice size container. Look at the oil in the sun for flakes in the oil and shiny pieces in the oil and look real good in the oil filter. Flakes:....look for new motor.
    Whats the mileage?
  9. Drakemyers
    Illinois
    Its got 180k miles on it, which isn't too many compared to other prii. I thought it was the valves also, but it doesn't really sound like it is coming from the head, more like something rattling. The noise is louder under the car. I have knowledge of the Prius engine, as I recently cashed out on my volkswagen diesel to go hybrid.
  10. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Louder under the car is not valves. You can keep driving it and the knock sensor will eventually detect it as it gets worse and pull timing and the car will feel like a dog with no giddeup. Sometimes it will throw a misfire P3002-3-4 also. People have continued driving it after that usually much harder since its such a dog now and that ends quite dramatically with a piston through the block.
    Try my rod to the ear to the pan trick. You will not like what you hear.
  11. bisco
    52,876
    through in a salvage engine and tranny, cheap money.
    edthefox5 likes this.
  12. Drakemyers
    Illinois
    thanks guys! bad news, but thanks! i will probably just trade her in.
  13. bisco
    52,876
    great deals on newer pri out there!
  14. edthefox5
    10,096
    4,840
    Clearwater, Florida
    yep...about 2 months from now we will see a new guy here complaining about his new to him car making a funny noise ....lol
    Cause they'll take that thing right to the auction and somebody will think there getting the deal of a lifetime!!!
  15. JC91006
    16,937
    8,647
    This is what my engine sounds like......and it's been going on for over 35k miles. I take it on 600+ mile trips and never had an issue. I still have not identified the problem. Sounds like a sewing machine
  16. bisco
    52,876
    or throw a rod, then come here complaining that these cars are supposed to last 500,000 miles.:p
  17. Drakemyers
    Illinois
  18. JC91006
    16,937
    8,647
    You don't need a new engine, the car runs fine with that noise. In fact, it's the most responsive of my 3 gen2 cars. This is the best car I've owned LOL
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    The difference is on his engine sound when he went by the wheelwell I can clearly hear lower end booming. Yours all I hear is noisy
    top end. His probably saw oil starvation somewhere in it's life probably extreme.
    Drakemeyers should probably go to toyota.com/owners and join the the members club. Then search his vin and all the service records the car ever saw in its life will be listed there. Probably some interesting reading. I bet it was dealer oil change maintained.
    Moot point...180K is a good run in any car. Drive it till it explodes.
  20. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Sorry, my phone must not be true enough to hear that as lower end noise. It sounded like valve tick through that tinny little speaker. Just listened on my headphones, and it's clear that's not quite right. If you've got lower end knocking, I agree with the "drive it till it explodes" camp. Sorry. :(
    #20 johnnyb588, Oct 27, 2015
