2007 Prius - Misfire Cylinder 1
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by KitsuneVoss, Dec 18, 2024.
  1. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    My roommate's Prius, a 2007, had a misfire on cylinder 1. Over the last week, I replaced both all of the spark plugs and the coils and cleared the code. Still misfiring after replacing all of them. Same place, cylinder 1, so does not appear to be anything I have done.
    Anything else which could be a common cause?
    Also cylinder 1 is the cylinder closest to the passenger side?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,860
    6,822
    Texas Hill Country
    injectors
    Brian1954 likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,975
    917
    Southern California
    Replaced the coils with what brand, from where? Aftermarket coils can be DOA, "OEM" ones from Amazon or Ebay can be fakes. Ditto for the plugs. That said, there is only a 25% chance that a bad component would end up on the same cylinder. So I agree with the previous post, a bad injector is the next thing to consider. After that check the wires to the injector and coil pack.
    However...
    Better to start by swapping parts between two cylinders. If the problem moves with the part you have found the problem - only then buy a replacement. Replacing the plugs with new ones is a small enough expense that there is no harm in doing that, as along as you are confident the plugs are the right type from a reliable source. Coils and injectors are more expensive, better to prove one is bad before replacing it.
  4. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    While the injectors can be expensive, doesn't look that hard to replace them from watching videos when it comes down to it.
    Likely wait until my own vehicle situation is solved so that that we have a backup however
    Try a fuel injector cleaner because cheap and easy in the meantime
  5. rjparker
    10,860
    6,822
    Texas Hill Country
    From yesterday
  6. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Um, I suspect just getting new injectors is cheaper than putting them through the bath due to the cost of the bath machine
  7. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I am pretty sure that spark plugs are good because they are Denco from O'Reilly's but I can easily switch coils between 1 and 2 as a quick test. Be a few days, Friday or Saturday, but still not a big job.
  8. Leadfoot J. McCoalroller
    8,235
    7,736
    Pennsylvania
    2018 Prius c
    consider a rebuild service for the injectors. It's much cheaper than OE replacements, and a rebuilt Toyota injector works very well compared to "discount aftermarket."
    The downside is car downtime while waiting for the injectors to be mailed there and back.
  9. Hayslayer
    Hayslayer Active Member
    508
    306
    Hopefully that's not the Chinese version of Denso :D
  10. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Well, nobody said I could spell
    You can buy remanufactured / refurbished Denso fuel injectors. Should I just purchase them if neither flipping the coils or running a fuel injector cleaner helps? They look like they are a little bit more than "Discount Aftermarket" but nothing like new as far as price.
  11. Leadfoot J. McCoalroller
    8,235
    7,736
    Pennsylvania
    2018 Prius c
    You might be on to something there. That option didn't exist the last time I had needs, so I paid the $25-30 per injector and the shipping and did it that way.
    So I know an OEM injector can be rebuilt to proper standards, I just don't know if those particular rebuilders are doing it right.
  12. Hayslayer
    508
    306
    You're right about the injectors. I was looking at new ones a year or so ago, and seem to remember RockAuto.com offered the rebuilt OEM injectors at a pretty fair price.
    #12 Hayslayer, Dec 19, 2024
  13. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I know this thread is old but watched a video on replacing the fuel injectors.
    I have a whole set of remanufactured ones ready to install (From Rock Auto as a best source).
    Video I watched has a lot of problems with leaks.
    Any suggestions? Seemed like he did best using the original seals?
    I can also order them from Toyota? Does that usually make it easier with less leaks?
    Edit: Just reuse the old ones as an option as well?
    #13 KitsuneVoss, Apr 14, 2025
  14. ChapmanF
    18,883
    When you come to the part of the repair manual that seems to be micromanaging you and telling you how to fit an O-ringed fuel injector into the fuel rail:
    Don't brush it off and think "I don't need no stinking instructions to put an injector into a fuel rail."
    Follow those instructions like the success of your job depends on it.
    If an O-ringed injector end doesn't get seated properly into the fuel rail, besides the risk of a leak, you have a risk that you bend or crush the injector when you tighten the rail down onto the head. Then you're out the price of the damaged injector(s).
  15. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I cannot tell exactly what is being shown in illustration B00061 right hand column?
    Not sure exactly what is different? Can you tell?
    Also, what manual is it from and what page? I have at least some of the official maintenance manuals?
    One item I notice is that they put the fuel injectors in the rail first and then in the head while the video I watched did the opposite.
    The TRQ video also has the injectors put in the rail first so I suspect it is the better way?
  16. Mendel Leisk
    42,166
    Belated comment: my first thought was "mailed"? Googled "business doing fuel injector cleaning in Greater Vancouver", one of the first results:
    Gasoline Injector Testing & Cleaning in Surrey - NW Fuel
    This page (about halfway down):
    Fuel Injector Testing in Surrey - NW Fuel Injection Services Ltd.
    shows gasoline injector "ultrasonic cleaning and testing", prices from $32.50 to $52 (CDN), 48 hour turn-around.
    There's also mention on the site: no charge if injector deemed unrepairable.
    Attached is from 2nd Gen Repair Manual, a bootleg pdf. Chap's second pic is in it, the first pic looks to be an image scan from some other document.
    #16 Mendel Leisk, Apr 14, 2025
  17. ChapmanF
    18,883
    The first I scanned from the gen 1 repair manual, which I have in dead-tree form.
    Yeah, starting with the injectors in the head is pushing your luck. It takes care and finesse to get the O-ringed ends properly into the fuel rail (not cockeyed, and not with the O ring displaced from the groove, the two flavors of 'WRONG' shown in the gen 1 picture).
    I can't recommend just plopping a rail down on four injectors stuck in the head and cranking the bolts down and hoping for the best. :eek: Leaks or irreparably-deformed injectors could be your reward.
  18. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I think it is done. First couple of times she leaked but I was able to get everything reseated.
    Almost more of an art than a science as far as I can tell.
    I had my roommate start her with the air box off the engine but with a rag over top of the intake.
    That way I could see the actual injectors to see which if any leaked.
    Did not see any leaks and put the air breather back on. Still saw no gas down by the rails.
    Car started getting pretty mad at us though.
    Roommate drove the car a few blocks after I was done.
    Several injectors look horrible.
    I think this picture will give an idea
    #18 KitsuneVoss, Apr 14, 2025
  19. ChapmanF
    18,883
    Some are more cavalier around possibly-spraying gasoline than I am.
    If I have installed injectors, I will leave the car off and jump power to the fuel pump and carefully check for leaks then.
    Only if there is no sign of leaking then do I proceed to starting the engine.
  20. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    How do you jump the fuel pump without starting the car?
