2007 prius misfire issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Montster88, Apr 1, 2020.
  1. Montster88
    Montster88 New Member
    San Dimas, CA
    Hi my friends,
    I'm new to this club and I am hoping someone can give me answers to my questions. I am an owner of a 2007 prius with over 211,000 miles on it. I have been getting sometimes extreme rough idle, check engine light on with misfire codes. What I have done is replaced the sparkplugs, coils, PCV valve, cleaned the MAS and recently replaced my VVT solenoid Sensor and I'm still getting the same problem with the gas mileage going down fast. Does anyone have a solution to my problem?
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Well since you’ve covered everything but the fuel injectors, you might start with a strong cleaner, and it that doesn’t work replace them! You can get a set of 4 on eBay under $50.
    SFO likes this.
  3. PriusUkTech
    PriusUkTech Junior Member
    UK
    ----UK----
    Egr and cooler disconnect the egr plug check if still misfires if No clean both parts there's a link in the gen 3 forum on how to
  4. JC91006
    16,896
    8,629
    I would suspect the problem is with fuel injectors or a bad fuel pump. You can test to see their performance or if they are cheap enough, you can just change them out (injectors)
    Raytheeagle likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    If its the original hybrid battery that's an amazingly good run. bet it spends alot of time in purple bars and you now have to really floor the car to get going. You may not even notice how much harder the engine has to work and all of a sudden the engine is running rough and its not happy with the beating its getting. How much oil does the engine eat between oil changes? How many times has the engine run so low on oil the engine light came on?
    How many times have you heard the fan come on in the back seat? But no matter whats going on with the engine you will be dealing with that hybrid battery soon.
    Soft hybrid battery is really the #1 reason your mileage is tanking. Hybrid battery supplies the bulk of propulsion power without its full contribution the little engine has to supply all the power and that's not good. Its an under powered go kart at that point with terrible mileage.
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Welcome to PriusChat!!
    Are there any OBD2 codes (DTCs) you can share with us?
  7. dolj
    dolj Senior Member
    8,625
    4,381
    Wellington, New Zealand
    Just for others coming to this thread, the Gen 2 does not have an EGR system, so it is not prone to those problems unlike the Gen 3 which does have an EGR.
    SFO likes this.
