2007 Prius - New AC Compressor (Oil)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by CYoung, May 20, 2020.
  1. CYoung
    CYoung New Member
    Sacramento
    I just finished installing a new ac compressor (electric), condenser & radiator in a 07 Prius. I planned on having a shop add the oil & refrigerant (I pulled the AC fuse so the compressor would not run while dry). Now the shop is telling me that I need to add the oil before they'll charge the system. Any thoughts on how I can accomplish this the easiest way? Is my only option to remove the compressor and add the oil to it?
    Does anyone know how much oil I need to add (again it's a new compressor & condenser, and I had the system evacuated before starting the repairs), to the compressor? From what I've seen in the manuals its around 4 floz. Also, where is the best place to add the oil to the compressor, once I remove it from the vehicle? Should I pour it in the suction end or discharge end of the compressor?
    Thanks for any advice!
  2. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    MAKE SURE you are using the correct oil!
    You cannot use regular A/C compressor oil, it has to be specifically formulated for hybrid cars.
    SFO likes this.
  3. jjmerp
    jjmerp Junior Member
    51
    22
    Ohio
    Advanced Auto Parts
    Part No. HYB-1
    This R-134a Hybrid Vehicle A/C Compressor Refrig. Oil is specially formulated for hybrid vehicle R-134a A/C electric compressors.
    Product Features:
    Specially formulated for hybrid vehicle R-134a A/C electric compressors
    Dielectric formula keeps voltage from leaking into compressor case
    Compatible with factory oils: ND-11 (Toyota) and 38899RCJA01 (Honda)
    Pourable 7 oz. oil
    SFO likes this.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Pinging @lech auto air conditionin for additional expert input, which we're always grateful for and may never express enough.
  5. Prius92
    595
    122
    Iowa
    Yup. The factory ND-11 oil is pricey too.
  6. CYoung
    CYoung New Member
    Sacramento
    Thanks... I have the ND-11 Oil.
