2007 Prius not starting
Discussion in 'Gen 2 Prius Technical Discussion' started by Rogger Willis, Jan 3, 2012.
  1. Rogger Willis
    Rogger Willis New Member
    I have a 2007 Toyota Prius. When I press the brake pedal and press the start button the engine does not start or the wheels are not powered by the battery. It gives me the following errors;
    The indicator in the Start button lights in Amber Color.
    0 kmph mark is not activated in the dash board pannel.
    When I shift the gears it only shifts to neutral ("N") gear.
    I cant move the car forward or backward. An error message is displayed in the MFD in Japanese language. It is in Japanese and I cant read the error message.
    Can anybody translate this message to English and give me advice what to do with this?
    I really appreciate that as I am stucked with this car with out a propper dealer in my country.
    I can't post a link to the picture of the error message as I am still new to this site. Hope you would be able to help me.
    Please help..
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Sounds like your 12v battery is dead. Hook up a 12v charger and try and boot that way.
    Make sure you connect the 12v jumper polarity correctly. Incorrect polarity may irreversibly damage your inverter (~$3,000USD).
    You can use the jump start terminals under the hood.
  3. Rogger Willis
    Thank You very much. I rechrged the battery and installed. It worked.
