2007 Prius P0AA6
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RJEFF001, Aug 20, 2019.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I don't think you can see any crack in there, with soap.
    You used soap bubble, only if a system is pressurized. So there's no way you could get any leaks showing. Remembered, the modules concerned is/are already leaking (leaked). And if it didn't even leak, how do you get the modules pressurized while its charging? Would be a risks!
  2. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Yes I charged the system and waited to get it a bit warm. I temp solved the issue by isolating the mounting bolt from the frame. The cell itself is actually the strongest in the pack. I get 5400mAH. That leads me to the next question. I have a friend that will sell me his 2013 pack from a salvaged Prius 40k miles on it for $500. Or do I get a 1 cell and use my current pack? I tested 1/2 the cells and with my current setup couldn't do a realy fast drain (1.6 amps down to 6.8 volts before time of 180 minutes ran out, had 3800mAH). That seems I have atleast 60% capacity left.
  3. Patrick Wong
    18,210
    6,517
    If all 28 modules are original from the 2013 Prius (without some having been swapped in from other vehicles), that sounds quite good.
    Skibob and Raytheeagle like this.
  4. sugar land dave
    137
    houston
    Patrick, you have been a great source of information for many years!
    Raytheeagle likes this.
  5. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    I like Patrick a lot.
    There's a guy also called @Britprius . Never heard from him again.
    We have a lot of guys over here that are just so fantastic. They kinda come over once awhile to make comments over here.
  6. sugar land dave
    137
    houston
    Yes, Britprius post on mobility batteries helped me replace my dead 12v battery yesterday. Fitting mobility 12volt AGM battery. | PriusChat
    I posted pictures there with comments if anyone is interested.
  7. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    A friend is supposed to bringing pack by tonight or tmw. Will see what he has. Knowing him it will be a pack from a 2003 (not 2013, these non car people, they just can't go anywhere without us car people :LOL:)
