2007 Prius P1116 code and coolant control valve issues
Discussion in 'Gen 2 Prius Technical Discussion' started by mpbrisson, Jan 11, 2009.
  1. Patrick Wong
    18,210
    6,515
    This is very strange. You noted that the cabin heater is not providing heat, but the car overheats. From this I conclude that the engine coolant is not circulating. This may happen if the tech did not properly purge air out of the engine coolant loop.
    Note that 87200-47030 is the electric pump used for the cabin heater system. I am wondering whether it is possible that the electrical connection to the pump might be loose. If so, that would be another explanation for why the cabin heater is not working, but this would not explain why the engine is overheating.
    If you can still stand to deal with this dealer's service dept, you may want to inquire whether the engine coolant loop was purged of air, and if so how long did the tech run the engine before releasing the car to you. If after 15 minutes of driving the car in freezing weather the warning lights appeared, it doesn't seem likely that the tech ran the engine very long when purging air out of the system. Perhaps you might ask the service manager to have the Toyota regional rep come out and teach the dealer's tech how to purge air out of the engine coolant loop.
    Good luck dealing with this very irritating problem.
  2. mpbrisson
    mpbrisson New Member
    Manteo NC
    It’s been a solid week since my last post. My last post described my Thursday evening (2/5/09) dealership service debacle. On Friday afternoon (2/6/09) at approximately 2pm I received a call from my Toyota Corp case manager. She was returning the phone call that I placed to her Thursday night after leaving the dealership. I had not spoken with the dealership yet on Friday, but she had just gotten off the phone with them.
    The case manager claimed that the service manager at the dealership told her that when they (she and 4 techs) checked the vehicle Friday morning, I had been running the AC…that’s why the vehicle would not warm up. Well, I hit the roof…I asked her if she, the case manager, knew anything about how the climate control worked in the prius. She said no. I told her that the AC has nothing to do with the temperature of the air coming out of the vents. That is controlled by the temperature gauge. In fact when ‘Auto is chosen to regulate cabin temperature, the default setting is ‘AC’. I then thought to myself, how is it possible that a ‘case manager’ knows nothing about how the vehicle they’re representing operates? I asked her if she thought it was possible that after 2 years of owning my vehicle I did not know how to operate my climate control, and if that was the case, how could she explain the ‘red exclamation point’ and ‘problem’ and ‘red thermostat’. She explained that the dealership experienced no warnings, no problems, no codes on Friday morning.
    I read her the riot act and asked her to send me info about Toyota arbitration. I also contacted my lawyer and began investigating NC Lemon Laws.
    After I got off the phone with Toyota Corp. I called the dealership. I decided to drive up there at 2:30pm to get my vehicle. The vehicle that less than 24 hrs ago would not operate. It was 90 minute anger stewing drive. When I arrived I had a heated discussion with everyone involved and brought up the same questions I asked of Toyota Corp. Do you know that my main tech admitted that he never looked at the climate control temperature gauge which had been left on 76 degrees? They all assumed that because the AC light was lit, I was running the AC for cold air…unbelievable. I asked the service manager why she threw me under the bus with Toyota Corp, telling them I had the AC on. She called it a miscommunication. I asked them all if it was possible that all the air had not been bled out of the cooling system causing a malfunction….that I understood that it was difficult to purge all the air. They said yes, it was possible. The tech also told me that he had brought the car in again Friday morning to test it and got no codes or warnings….he also bled the cooling system again.
    After all that, I drove my car home Friday night, and so far it’s running well. My case is going to be held open for another couple weeks, but I do hope this epic is over. I want to thank everyone who posted for making me sound like I knew what I was talking about when I discussed the issues with Toyota or the techs. I hope I don’t have to post in this thread again. Thanks.
    dboy and dave77 like this.
  3. Patrick Wong
    18,210
    6,515
    Thanks for the update. How many miles have you driven since Friday night?
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Its too bad that you can't buy these things factory direct with a comprehensive maintenance guide and any special tools needed.
    I have absolutely no use for my dealer after they lied to me about aligning my car. I need to get the squealing coolant thermos pump replaced on mine, but I keep putting it off because I don't trust them to bleed the system properly.
  5. Patrick Wong
    18,210
    6,515
    Hi J.,
    It's not that hard to bleed the engine coolant; if I can do it (without benefit of having the Toyota diagnostic laptop) I am sure you can also. Just need to allow plenty of time, measure the drained coolant, and not be satisfied until you've added back the same qty as was drained.
    A dealer tech probably does not have the luxury of spending plenty of time on any one job, being under pressure to complete work fast.
  6. dogfriend
    7,512
    1,190
    Carmichael, CA
    I know that I could do it; I wouldn't move the car again until I was satisfied that I got all the air out - but then I would have to buy the coolant pump (~ $200) instead of them replacing it under warranty.
    Still, it might be cheap insurance to make sure it gets done correctly.
  7. mpbrisson
    Manteo NC
    As of Sunday 2/15 8pm, the MIL light is on again. Car went a week and 2 days this time....about 300 miles driven. The saga continues.....
  8. Patrick Wong
    18,210
    6,515
    Hmm, this is very disheartening.
    Any symptoms besides the check engine light?
    How is the cabin heating working?
    Do you hear air bubbles in the heater core?
    Did you happen to note the cold engine coolant level in the overflow container when you got the car back last week; if so, has this level decreased now?
  9. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    same p1116 code? sounds like these guys are bumbling idiots.
  10. mpbrisson
    Manteo NC
    The cabin heat seems to be working fine. I did notice that the car is much quieter since the last repair after shutting down. It's not squealing. Since this work has been done, there is one thing going on after shut down and right after start up....sounds like a waterfall in my car. After one of the earlier visits, the dealership tech told me I would hear that at first but it would go away, but it continues to do it. I honestly don't ever remember the vehicle making 'the waterfall' noise before I started having problems.
    I'm not mechanically inclined, though I'm learning a lot these days, so I haven't checked any fluid levels or know that I've heard any bubbles.
  11. dogfriend
    7,512
    1,190
    Carmichael, CA
    I don't think we can assume its the same code.
    I would check the coolant level in the see through reservoir at the front of the car to make sure its not low on coolant before you drive it again.
  12. Patrick Wong
    18,210
    6,515
    The "waterfall" is probably the coolant heat recovery pump running. Upon startup, it moves hot coolant from the storage canister to the engine to reduce engine warmup time. Upon shutdown, it moves hot coolant from the engine to be stored in the canister.
    I agree that you should check the overflow container located near the radiator to see if, at minimum, some pink coolant is within.
    Are you planning to return to the same dealer; or try a different one?
  13. mpbrisson
    Manteo NC
    I am seriously considering arbitration at this point. I have no confidence in the vehicle. I have no confidence in the folks working on it. They tell me it's probably fine to drive, but how can I trust that when they cannot even repair what they 'think' is wrong with it. I am so tired of driving back and forth to the dealer over and over again and getting the same result....that's the definition of insanity isn' it? I am souring toward this vehicle, but I can't imagine driving another.
    I'll drive by Advanced Auto today to see what code pops up on their scanner. I checked my coolant level...definitely pink all the way to the full line....
    I feel like parking it, and if toyota wants to keep working on it, they can come tow it. I feel like the money my wife and I have spent paying for this car has been waisted. Even if there's a favorable arbitration, that money is flushed because I had 2 great years of driving....it's the same as driving a rental car for two years.
    Any thoughts on going down the arbitration road???
  14. Patrick Wong
    18,210
    6,515
    Yes, it would be very interesting to see whether your car has the same code, or a different code.
    What result do you expect from arbitration: do you want Toyota to buy your car back?
    Although your next closest dealer is so far away, you've given the first dealer several chances to fix the car and they've proven that they can't. So if DTC P1116 still appears, it might be reasonable to try the next dealer and see if they can do better.
    Since you've checked the engine coolant level and found it to be satisfactory; if the check engine light is the only light on and you do not see any warnings regarding overheating, then you can probably drive the car without causing further damage.
    Good luck.
  15. mpbrisson
    Manteo NC
    I'll have the code checked out.
    Tomorrow I'll speak with Toyota Corp. I plan on asking them to find me another dealer and telling them I want it towed. I don't think that's unreasonable at this point.
    What do I expect to get from arbitration? To be taken I'm sure. I expect a fair reimbursement or replacement of the vehicle with the same make and model. According to the owner's manual, arbitration is necessary before taking them to court in NC. I fit every single Lemon Law criteria in the state of NC. I can accept or reject the settlement and go to court if necessary.
    I drove my last car (VW Golf) for 15 years, and had planned on doing the same with this one. I had less trouble with that one in 15 years than I've had with this one in 3 months...it's my first Toyota and it's a shame because I can't imagine driving anything else. I take care of my cars.
    I just know every time I turn this car on that little yellow bastard light is coming on. It feels like everything I've spent on this vehicle has been wasted...like I've had a rental car for 2 years. This car will have been paid off at the end of this year, and right now, it looks like I'll have nothing to show for it.
    I'll let you know on the code. Thanks for all your help.
  16. mpbrisson
    Manteo NC
    :mad:Ladies and gentlemen....drum roll please....
    Definitely another P1116 code! I dropped by Advanced Auto on my way home from work.
    This is crazy...They've done $3000 worth of work to my vehicle, I haven't driven my car for longer than a week in 3 months, and still the same code. Are they just tinkering, replacing this and that because they can't figure it out?
    I'll be discussing my case with Toyota again tomorrow.
    MB
  17. dogfriend
    7,512
    1,190
    Carmichael, CA
    Yes, it appears that way. They are probably just as sick of your car as you are of them. Not your fault though.
    It seems like they have replaced every part in the system except for the ECU and the harness. I think it is a wiring problem. If I were them I would either meticulously check every applicable circuit or just replace the harness at this point.
  18. Patrick Wong
    18,210
    6,515
    See posts 14 and 16 from CheapA55. I am wondering whether it is possible that the coolant valve was incorrectly installed, as was the case with his car. The TSB in post 16 has a diagram that shows how the plumbing should be routed.
    The repair manual suggests reviewing freeze frame data to determine exactly when the trouble code was logged. That may provide a clue as to whether or not there is a real problem being reported, or a glitch in the engine ECU.
    Another troubleshooting technique might be to see whether or not there is a real problem triggering DTC P1116. The repair manual suggests two faults that provoke this DTC:
    - As the hot coolant flows out of the tank, the temperature change registered by the sensor is less than 3 degrees C
    - After the pump has run to move hot coolant into the engine, the difference in temperature between the coolant thermos sensor and the engine coolant sensor is greater than 25 degrees C, which implies that the hot coolant did not actually reach the engine.
    I suppose the tech could use an infrared thermometer to see whether these conditions actually exist, which means that the DTC was justified in triggering, or not. If yes, then figure out where the plumbing problem is. If not, then a sensor is bad, the wiring to the sensor is bad, or else the engine ECU is bad.
  19. galaxee
    9,810
    471
    MD
    time for an ecu swap.
  20. mpbrisson
    Manteo NC
    If the coolant valve was installed incorrectly, wouldn't the MIL have come on immediately? There has always been a delay after leaving the dealership...2 days, 3 days, 1 week. It seems to me that the outside temp has been cooler when trouble arises (30-40 degrees), and that's more in tune with the temperature/sensor issues. My problems started in November and the outside temp hasn't been above 60 more than a couple times since.
    I get the feeling that most of you think I should keep plugging along, perhaps change dealerships, let the 'experts' figure this one out. Does anyone out there feel that arbitration is a viable alternative?
