2007 Prius P1121 Code
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Meh1483, Jan 29, 2018.
  1. Meh1483
    Meh1483 Junior Member
    27
    First time poster Here! Forgive me if I'm clueless. My 2007 Prius with 102,500 miles has been making a strange noise (see YouTube link below) and now the check engine light has come on. I checked the code at AutoZone and it's P1121. How urgent is this to repair? The check engine light disappeared yesterday and is back on today. Should I have the coolant level checked? I'm definitely not a DIYer. I see that I should only use the Toyota Super Long Life coolant. I'm not sure if that's what I have in there now, so if it's low, should I have it flushed before I add the Toyota coolant or just top it off? Thanks so much for any advice!
  2. padroo
    padroo Senior Member
    2,763
    2,253
  3. padroo
    2,763
    2,253
    Short video telling you how to check your coolant. His advice is pretty good except his coolant should be pink and not green.
  4. SpaceCityHybrids
    38
    52
    Houston
    Coolant valve is a common issue on these cars. It's not a difficult DIY fix if you have some experience on cars. You can find the part on Amazon.
  5. Figster10
    Figster10 Member
    207
    61
    Sacramento
    Is that low train choo choo sound he has in the video related to the coolant control valve going out?
  6. ruggb
    ruggb Junior Member
    67
    Cary, NC, USA
    looks like I would recommend buying this part at a local parts place since apparently, it isn't uncommon for it to need replacing again.... and again...I replaced mine in April 2019. It is Nov 2019 and the P1121 came back. I refilled the overflow tank and it went away for about 30 days. Now it is back and everything is still full, so I guess I need to warranty replace this part AGAIN. Is there a good reason these parts keep jamming up?????
  7. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Not really, they should last a good long time. Maybe look at your methods, or the parts you are using.
    I wouldn't recommend using old parts unless you like doing the job over and over.
    What Parts and coolant (Brand/Type) are you using?
