2007 Prius - Passenger side(rear door) does not unlock from inside
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Jun 19, 2017.
  1. tampaite
    tampaite Member
    237
    42
    FL
    I hope everyone had a good Father's day weekend!.
    We are unable to open the rear passenger door from the inside using the handle. The only way we can open is with the FOB key and this issue just started over the weekend.
    Where do I start to troubleshoot?
    This only happens with the 1 rear passenger door and all other doors work(unlock/lock) manually.
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Did someone inadvertently flip the child lock on the door?
    Tyfly and tampaite like this.
  3. JC91006
    16,938
    8,647
    Something probably got loose in there, take apart the door panel and trace the connection.
  4. tampaite
    tampaite Member
    237
    42
    FL
    That was it - No idea how that got flipped but am posting an image of what it needs to look like.
  5. JC91006
    16,938
    8,647
    You put on your first post "the only way we can open is with the FOB key"? what does that mean?
  6. tampaite
    tampaite Member
    237
    42
    FL
    by pressing on the unlock button twice on the key
  7. JC91006
    16,938
    8,647
    That does not bypass the child lock
  8. tampaite
    tampaite Member
    237
    42
    FL
    I just tried again. turn ON the child lock - the only way to open the door is click twice on the button otherwise, you cannot open the door from inside.
    Oh i c maybe the confusion is - when you click on it twice, you need to have someone open the door from the outside - you cannot open the door from inside when you double click on the button.
  9. JC91006
    16,938
    8,647
    ahhh, ok that makes sense. opening from the outside.
