2007 Prius, red Triangle, New 12v Bat
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dillon Selph, Mar 25, 2020.
  1. Dillon Selph
    Dillon Selph New Member
    Hazlehurst Ga
    Hey Guys, I have a 2007 Prius I bought and am the 2nd owner, they had recently replaced the Hybridd Batt. that I hit a deer with in Dec2018. Afterwards it would still crank. Funds got tight so I could not repair it. I would still crank it from time to time. One day the Batt died (12v) and I jumped it off and all was fine. Batt died again in around sep 2019. I sent it to the body shop finally and when they finished it would not crank. We replaced it and it still will not crank. It threw up an error code involving to Hybrid Batt wasn't charging or something of that sort. Any idea on what I should do? or advice?
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Care to share the error code (DTC) ?
  3. Dillon Selph
    Hazlehurst Ga
    Sadly I didn’t write it down but he’ll be back and I can post it then!
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    The Prius, like most hybrids does not "crank" upon initial "starting".
    I think you need the services of a real Toyota shop.
    And/or a better description of what is really happening.
    If the replacement HV battery is a "rebuild", it might be bad again.
  5. Dillon Selph
    Hazlehurst Ga
    Hey finally got the codes it’s:
    C1259
    C1310
  6. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
