2007 Prius - Red Triangle, Overheating sign, Coolant disappearing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Polder, Sep 26, 2018.
  1. Polder
    Polder New Member
    Pittsburgh
    I've searched across the forum for clues to what might be the issue, but would like to troubleshoot a bit more and get to know possible fixes.
    Car: 2007 Prius
    Mileage: 95k miles
    Issues began happening days after driving over 8 hours with a fairly heavy load (moving home), our Prius got the red triangle and then moments later a red thermometer sign while going slightly uphill. No issues during the long drive.
    Since then, I have experienced the following:
    • ICE coolant reservoir was empty and I had refilled reservoir (twice) with pink coolant
    • Weak acceleration on flat roads and weaker on hills
    • Heater not working
    • Red triangle/overheating symbol whenever driving longer distances + uphill
    My initial thought was gas bubbles in the coolant system but would that explain the missing coolant? After some more research, is it possible it is a head gasket issue? How do I diagnose/fix this issue? How much would a mechanic charge for this?
    52,883
    yes, it is possible. check your oil for coolant contamination. a mechanic would perform a cylinder leak down test to see if the head gasket is blown, probably a hundred to two hundred dollars.
    Polder likes this.
