2007 Prius Red Triangle while driving.
Discussion in 'Gen 2 Prius Main Forum' started by Danni, Apr 21, 2020.
  1. Danni
    Danni New Member
    Little Rock, AR
    I have noticed that my 2007 Prius’ red triangle will come one while driving, usually around a corner (or so it seemed). Yesterday I was able to take a few videos of what actually happens. Does anyone mind looking at them and telling me if you might know what’s going on?
    Mileage: 151k
    Hybrid Battery replaced: 126k
    Oil last changed: June 2019
    Thank you.
    Danielle
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Welcome to PriusChat!!
    The red icon in the upper left corner of the MFD could be the give away, how often do you check the engine oil and fluids in the vehicle?
    Best to check the engine oil on a level surface, and if possible after the vehicle has sat for a period of time, or overnight.
    Lack of regular vehicle maintenance, and especially low engine oil levels will kill a perfectly usable prius fairly quick.
    You can learn what the various dash warnings and symbols mean by reading the manual.
    If the vehicle didn't come with a set of manuals, you can find them at Toyota Warranty & Toyota Manuals | Toyota Owners
  3. strawbrad
    953
    1,007
    You need to get some oil in the engine pronto!
    Some level of damage has already been done by driving with low oil.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Hi @Danni,
    That red icon in the upper left corner of the multi-function display means you're experiencing low oil pressure, which can very quickly lead to the death of an engine. I would recommend NOT driving the car at all, or even starting it again, until the oil level is checked and corrected.
    Low oil pressure does not necessarily mean NO oil pressure, so your best option is to top it off and fire it up. Keep a close eye on oil level every day or two for a week or so to see if you're experiencing abnormal consumption. Toyota considers excess consumption to be burning more than 1 quart of oil every 600 miles.
    Seeing this icon means immediate attention is needed:
    #4 TMR-JWAP, Apr 21, 2020
  5. PriusCamper
    PriusCamper Senior Member
    13,427
    5,421
    Pacific Northwest, USA
