2007 Prius repair - second opinion
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tampaite, Oct 30, 2015.
  1. tampaite
    tampaite Member
    237
    42
    FL
    So you'll know I changed my oil yesterday at 6K interval.
    I took it to the nearest Toyota dealer since I was pressed for time.
    Dealer recommended the below repairs and I wasn't expecting it so reaching out to PC for help.
    Background: 2007 Prius regular model has approx 150K miles on it. Second owner - first owner took good care of the vehicle(owner performed all services at Dealership). Everything is Original and all re-call work has been performed on the car as far as I can tell.
    1. Transmission Service - approx $175
    2. Brake System - Rear - Clean and Adjust - approx $70
    3. Engine and Inverter coolant flush - approx $440
    4. Belt - Drive belt has badly cracked - approx $140
    5. EFI and Induction Service Tune up - approx $300
    Prices quoted are final(includes labor and tax).
    I got in for a $25 oil change and I got $1000 in repair quote :)
    My biggest concern is the drive belt - do I need to get it replaced ASAP.
    Brake pads am told had 35% life left - so not sure if thats also an ASAP repair thats needed.
    Visually am unable to say if it needs to be replaced or not but at 150K miles, probably think its due - what do you suggest?
    #1 tampaite, Oct 30, 2015
  2. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    Ugh---service departments sure are good at putting scary bills together.
    Did they say what the "transmission service" includes? The only thing the transaxle could benefit from is a fluid change (not flush), which I didn't think Toyota service departments usually offered to do (Toyota claims this is "lifetime" fluid). Shop around for this and specifically ask about a "transaxle fluid change".
    If the engine and inverter coolant has not yet been changed, it is something that should probably be done, but that sounds too expensive for that service. I would ask around some more. Do you have any other hybrid shops in your area? Call a different Toyota service department and ask for a quote on just the coolant changes.
    The serpentine belt should probably be replaced. How handy are you? The belt is not all that difficult to change yourself, bringing that charge from $140 to about $10.
    I'd have a look at the brake pads yourself, but 35% is still quite a bit remaining. Not an immediate concern, IMO.
    The EFI tuneup could include any number of things (or hardly any of them). I would have this one broken down into specific items. Chances are, you'd be fine completely avoiding this service but it may include a helpful item or two. Is it a good value?--probably not.
    The magic of the cheap oil change service is to get customers' vehicles into the shop for more expensive services that are actually profitable (and often overpriced and unnecessary).
    tampaite likes this.
  3. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    ^What tanglefoot says. Any dealership or private garage for that matter makes the most out of every opportunity to "go shopping" on every vehicle they see. Depending upon your mechanical abilities there are great How-To's for all those things from their shopping list on PC or Youtube.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    That is one of the better, more realistic one's I've seen. It wouldn't hurt anything to have any of those services done. If money is tight you can prioritize. I would recommend the following priorities
    1. Belt - Drive belt has badly cracked - approx $140
    2. Transmission Service - approx $175
    4. Brake System - Rear - Clean and Adjust - approx $70
    I would highly recommend you have your belt changed asap. The belt drives the water pump and that would cause an overheating event which could be catastrophic to your ICE. #'s 4 and 5 shouldn't be necessary if your car is running fine. The rear brakes are "self adjusting" to an extent and are probably fine. If they're worn to the point of needing adjustment, the shoes should be replaced. The EFI and Induction service may prevent future problems but $300 sounds like a lot of money for that service.
    #4 usnavystgc, Oct 30, 2015
    uart and tampaite like this.
  5. Patrick Wong
    18,210
    6,516
    Yes, the drive belt needs to be replaced. The engine and inverter coolants are supposed to be replaced at 100K miles, then at 50K mile intervals subsequently, so that is also due. The transmission ATF needs to be drained and replaced.
    I would skip #2 and #5 from your list above, unless there are signs of problems in either area.
    If the front brake pads have 35% life remaining then there is no need to replace those at this time. Consider doing that after you've logged another 50K miles or so.
    The quoted prices are high but what do you expect from a dealer service department. If you can DIY you could do services 1, 3 and 4 for around $120 in fluids and the replacement belt.
    Also check the engine coolant pump for fluid weeping at the bearing. This is evident by pinkish or whitish deposits at the pump pulley interior and/or deposited on the AC compressor housing. If you see that, replace the pump.
  6. bisco
    52,662
    have any of these been done previously?
  7. tampaite
    tampaite Member
    237
    42
    FL
    Let me check the records and will come back on post in about 10 minutes...
  8. tampaite
    tampaite Member
    237
    42
    FL
    Looks like none of them have been done previously.
    I see only recalls and regular oil changes in my records
    • PERFORM 90L RECALL
    • PERFORM C0T SAFETY RECALL
    Is the drive belt or Serpentine belt one and the same?
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    With that in mind, I would have the belt replaced, the transmission service and the coolant service asap.
  10. bisco
    52,662
    yes, drive is serpentine. with nothing done previously, i think you need to step back and look at the recommended maint. in the manual, plus some things added by knowledgable members here.
    start with galaxee's 'what service you need and what you don't'.
  11. tampaite
    tampaite Member
    237
    42
    FL
    Thanks.
  12. bisco
    52,662
    pleasure.
  13. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I just had the "transmission service" done which consisted of drain and fill. The price was $75. Different part of the country but I have seen other posts of it done for $100. The labor on mine was just $36.
  14. bisco
    52,662
    good price! agreed, it shouldn't be more than 100, but i have seen people pay 120.
    Ozark Man likes this.
  15. vskid3
    vskid3 Active Member
    773
    228
    If you can DIY, those are all pretty easy to do. 5 is probably a bottle of injector cleaner in the fuel tank and cleaning the throttle body.
  16. tampaite
    tampaite Member
    237
    42
    FL
    so the transmission flush was $75 in total or $75 + $36?
    I guess my dealer wants $175 even.
  17. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    It's NOT a flush you want, you only want a "Drain and Refill" on the transaxle. Parts required 4 quarts Toyota WS Fluid, Two Crush Washers. NO FLUSH NEEDED. Had our old Gen II 2009 Prius done by Toyota, cost was $86 two years ago. (Parts and labor)
    Mendel Leisk, Ozark Man and tampaite like this.
  18. JC91006
    16,905
    8,631
    Are you sure your service records are complete? You can check the service records of the car by logging onto the owners portal at toyota.com. Put in the car's vin number and access all the records.
    If this car is at 150k miles and the previous owner did all services at the dealer, surely he would have done some of those maintenance items. I can't see how the sharks at the dealer's service department would not be able to push more services than just oil changes and recalls.
    usnavystgc likes this.
  19. bisco
    52,662
    agree.^^^
  20. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    It was $75 total, $80.09 I think with tax.
    dorunron likes this.
