2007 Prius retrofit backup camera?
Discussion in 'Gen 2 Prius Main Forum' started by gail1946, Feb 22, 2009.
  1. gail1946
    gail1946 Junior Member
    wa
    Does anyone know about what it might cost to have a dealer retrofit a backup camera in a 2007 Prius I'm buying used? Thanks.
  2. AussieOwner
    AussieOwner Active Member
    1,091
    67
    Sydney, Australia
    Cannot adivise on the cost, but you indicate that your package is the Base package. There is a difference between the MFD on the base models and those that have Nav and/or backup camera. The base MFD will not display the backup camera feed.
    You can do as I did and fit a third party backup camera - costs differ depending on the model and the way the screen is fitted in the car, but be careful about trying to link to the MFD.
  3. Patrick Wong
    18,181
    6,289
    It will probably be pretty costly to outfit the Prius with a rear camera. An alternative that you may want to consider is to have your dealer install proximity sensors in the rear bumper. A little speaker in the passenger cabin will make various sounds as the rear of your car approaches another object; I have found this works very well with my 2004.
  4. aaf709
    3,841
    For my 2005, if I got the OEM parts from Sigma Automotive and installed it myself, the cost would be around $700. As much as I'd like one, it's much cheaper to add a 3rd-Party camera system or go with the proximity sensors, both of which were mentioned before.
  5. FCBarca
    FCBarca Junior Member
    La Côte
    I'm in a similar situation but the '07 I'm buying has Navigation but no camera. I've found an original camera w/ housing on ebay but curious if that's all that is needed. Anyone know?
  6. tf4624
    tf4624 Active Member
    524
    51
    get a voyager camera system if you got the doe.. great picture and you can see
  7. ystasino
    ystasino Active Member
    793
    49
    Tucson, Arizona
    Don't take my word as a contract, but at least in the US I think that every package equipped factory Nav should have a rear camera, no?
  8. romad
    romad 2004 Prīus Package 6 Owner
    295
    Oroville, California People's Repub./Prescott, AZ
    Is the OEM camera color or b/w?
  9. FCBarca
    La Côte
    Yeah, this is a European model and oddly enough, it does not come with a camera despite the NAV package
    Want to purchase the part from ebay but still curious if it will actually work and if there are other parts etc. needed :confused:
  10. aerogowest
    aerogowest Junior Member
    Seattle
    If it had the OEM Nav originally, it had the backup camera; something is fishy.
  11. FCBarca
    La Côte
    Something tells me that isn't the case...I see a lot of Priuses here (Suisse) that don't have the camera
  12. direstraits71
    direstraits71 Member
    367
    62
    Central Coast California
    He's referring to the North American models.
Loading...
