2007 Prius - should I back out?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PR122, Dec 9, 2023.
  1. PR122
    PR122 New Member
    North Carolina
    Hi everyone. :)
    I am new here, and am close to finishing a deal on a 2007 Prius with 87k, but I was, fortunately, given a little time to take the car and check it out better, and I am have serious second thoughts.
    (Warning, this turned out rather long)
    The hybrid battery had gone out a year or so ago, but it had been replaced by Hybrid Battery 911 LLC (HB911) about 1.5 years ago, and the replacement came with a warranty that I would need to pay $100 to transfer, and then $20 a month for as long as I drove the car to insure the hybrid battery would still work.
    I was aware that the car had a problem with the combination meter due to the fact I was told about the dash lights having gone out on several occasions, which appear to be happening more and more frequently. The repair costs was estimated to be about $1,000, but if I am feeling really lucky, I could use some DIY videos and try to do it myself. I am not sure. I like to think I could do it, but it is more likely that I will take it to a repair shop instead of risk messing it up. As a result of that problem, the price was dropped from $8,000 to $7,000 so I could handle the repair.
    I had planned to drop a little more on the car myself. The cat had been stolen a year ago, but had been replaced. However, I know it would still need a cat shield, so that would be . . . $600? Plus, I thought I would take it and have the oil and filter changed, and check to see if it needed any other general maintenance.
    So that put me at roughly:
    $7,000 car
    $ 1,000 combination meter
    $ 120 Hybrid battery - transfer plus 1st month
    $ 600 cat shield(?)
    $ 400 maintenance (?)
    roughly = $9,120 (plus approx $650 for taxes, tags, and registration, so now close to $10k)
    HOWEVER . . . I drove it home last night, and on the way, when I stopped at a light, I started noticing this faint beep beep noise (or ding ding, can't remember exactly). I actually thought it might be the car antenna trying to automatically extend and being stuck or something, but the noise was in the wrong place for that. I heard it better when I leaned in closer to my steering wheel, and maybe more to the left side of it? It didn't happen every time, however, just every once and a while at a light I would hear it faintly.
    The other noise, that I initially ignored because it, too, was infrequent, was a sort of yip or bark when I was stopped. That, I thought at first, was that I was just happening to notice the street crossing signals, but then it happened a few times where there were no street crossing signals, and then I realized it was coming from the car.
    I do not believe this vehicle has ever had any real brake work, and from what little I know so far of Prius problems, it sounds like I may be dealing with a brake booster problem and/or and ABS problem (does fixing the ABS fix the brake booster?). I did find in the documents on it that it was eligible to be warrantied for the 'brake actuator assembly' if there had been any problems back then, but I think it was driven too little for the problem to crop up in time to have any work done. It is a shame no work was done because the first primary coverage went to Dec 31, 2017, and then gave a secondary coverage after the first repair for up to 10 years or 150,000 miles, whichever happened first.
    If this is the brake booster only, Toyota quoted me $1,353 plus a diagnostic charge of $190, so $1,543 because the only way to have them warranty it is to pay for the diagnostic, too. However, if this is the ABS, from what I have learned from reading online tonight (too late to call Toyota), it could then cost $3,500-5,000 to do that repair. Again, does that fix the brake booster, or is that an additional cost, too?
    I set up a 'pre-purchase' inspection for next week, thinking that Toyota would have some special inspection for a hybrid vehicle, but I then had them send me a list of what they inspect, and it was really, really basic, and nothing hybrid related. They want $300, but for $90, I can get the same at a regular mechanic.
    I started into this thinking I was purchasing a car with a $1,000 problem that I was willing to take on plus give it a few goodies, but that plus these other problems has suddenly exploded the price of this vehicle. If it needs an ABS, then I think I might be better off to pass on it and try to either find a later model Prius (like 2009?) that is not so prone to the problem, and likely save a few grand, too, or even a different type of vehicle. Also, and maybe this is just normal Prius behavior, but I didn't find it to have much pep. It seemed rather sluggish when I got away from all the stop lights, and the motor seemed rather loud and really needed to be pushed to get up to speed with other vehicles, and I am not even sure I ever even got to 60 mph. I was thinking it might be unpleasantly loud to drive on the interstate, and that I would have to keep pushing and fighting it to keep up to speed with everyone else. Is this how a Prius is normally at higher speeds?
    Thank you to anyone taking the time to muddle through all this - especially if you have any helpful advice to add. I would much appreciate it! :)
  2. PriusCamper
    PriusCamper Senior Member
    13,475
    5,441
    Pacific Northwest, USA
    Relax... You bought a great car with no issues of concern as far as I can tell. The Toyota Stealerships are dishonest as the day is long and don't do affordable car repair on older cars. They are warranty specialists who are trained to maximize cost of repair to help stealership have cheaper payments to Toyota.
    My advice is to enjoy your car and not worry about anything and buy a bluetooth OBD2 reader and use Dr. Prius App and Car Scanner app to get more information so you can plan to care for your car via yourself or a friend or family member, or at the very least an honest local mechanic who will work with us. Here's buyers guide for OBD2: Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Specific to your concerns:
    -- My combination meter has been dying for several years and every time it goes out I make plans to deal with it and then it doesn't go out for another 6 months to a year so I never get around to it. The combination meter is simply replacing a capacitor on the circuit board after pulling it from the dash. The easiest type of circuit board soldering there is. Not as easy as soldering two wires together, but fairly close. And it's not a $1K job. An honest mechanic would charge less than $200. Or you can pull it yourself and ship it to these folks: Prius Speedometer Replacement
    --Cat shields are as cheap as $40 these days: Prius Cat Shield Catalytic Converter Security Protection For 2004-2009 Toyota US | eBay and not counting the time & hassle to get the car a foot off the ground, most people can do the install in an hour with only having to purchase some new drill bits and a rivet gun.
    --The hybrid battery is not new, but rebuilt and even if you get it replaced under warranty the replacement pack is still only gonna be good for 3 months to 3 years and that $20 a month adds up compared to upgrading the MPG and overall performance of the car next time the battery goes out with a Lithium upgrade. And if you use my affiliate, I'll give you unlimited tech support on all your Prius needs: http://www.projectlithium.com/?ref=9qLPw
    -- Because the car generates electricity when you press the brake pedal you can go a really long time without wearing out the mechanical brakes. I'm just about to hit 280K miles on original brake pads and as an experiment have worn them all the way down and planning to replace in next week or two. Also, the biggest scam mechanics do out there is sell brake jobs for Prius because with certain driving styles the brake disks will appear rusted from lack of use. But put it in neutral when hard braking off the freeway and it will turn off the generator and your disks will lose all their rust.
    -- Original brake boosters are still going strong with Gen2 Prius at 500K miles sometimes. Also, brake boosters fail gradually. When you walk up to the car after a long time and open the door and sit down you'll hear the brake booster run. That noise on a failing booster will happen more and more often and once you hear that recharge noise every minute or so its time to replace. They'll be plenty of warning lights to remind you as well. But from the way you describe that's not an issue at all yet.
    #2 PriusCamper, Dec 10, 2023
  3. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Run, don't walk, away from this car. Get a non hybrid. Unless you want an unreliable project car on which to spend money.
    bisco and Brian1954 like this.
  4. Tombukt2
    Tombukt2 Senior Member
    13,875
    2,521
    Durham NC
    Buddy you're in North Carolina are you in the Raleigh-Durham area or up near the Queen City? You can do way better Why do you need a Prius It's 40 mpg super important and something you will be needing to utilize almost every day I doubt it most people here in North Carolina aren't really doing all that kind of driving that's why they live here they move from Massachusetts and points north where they drove 40 minutes one way to work now they drive 14 Do you really need the mileage and the driving of the Prius If not why are you not looking at the Yaris or a used Corolla It's just going to sit in the parking lot while you're in your fancy IT job working seriously Tell me where this car came from and I'll tell you probably all about it just kidding but I've probably already looked at it You haven't brought this car home to own it yet right? Are you in the 919 area code I'm in Orange county If you don't know where that is it's not important Good luck It sounds like you might be from not around here be careful.
  5. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    I think the car is overpriced for the issues it has. Low mileage on these cars is not worth a premium. But before you buy an old hybrid be aware repair cost at a shop will kill any gas savings. They are very reliable but there are several high cost repairs that happen and are unique to hybrids. ABS pump and battery are the worst. You may find a better deal buying a non hybrid that get 30s mpg but has less issues.
    Brian1954 likes this.
  6. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    You are one of the very few buyers who research before you buy the most complicated and difficult to fix cars.
    A rip off for reliability. You will be fixing this every six months instead of ten to twelve years with a new $2500 battery.
    Accurate costs but not optional. Sometimes you can’t start or stop the car.
    It may happen again. Another strike against reliability.
    $2500 and a real safety issue. Sudden hard brake and extended stopping distance may make you the cause of a crash. Most likely totaling the car because of high cost of repair. Increased insurance later. Willing to risk it?
    95% of regular mechanics can’t diagnose a Prius or tell you much. Most won’t work on them. So it’s diy or dealer for most.
    Especially with a weak hv battery.
    They also frequently burn oil in their declining years.
    You know the answer. But most fall in love with the idea and buy anyway thinking mpg will compensate. Maybe it helps at $4 a gallon but the brake booster alone will drain those savings.
  7. Tombukt2
    13,875
    2,521
    Durham NC
    Unless you're a can do person and you're using used parts You've got to realize now that a lot of these cars heading to the junkyard I've already had the brake booster replaced The hybrid battery came along and snafud food the whole car. At least that's what seems to be happening down here in the dirty south people are putting these expensive parts on these cars and then the battery goes bad or they put in a battery and then the brake booster goes bad so now I'm getting a fairly new battery and a bad brake booster car the next car will be opposite so on and so forth so it just depends on your situation really I bought two cars just recently have I don't know $1,300 in the two vehicles sitting here at my house one vehicle needs a brake booster the other vehicle needs a balance battery setup It's on its original I think other than that everything on the car works great so I got a balanced battery rack install that and put 5,000 mi on the car without a hitch The car that needs to brake booster I was just at LKQ the other day and got a brake booster for pretty much free 50 bucks or something and I can return it if it doesn't work It looks like it has been dealt with in this particular car so I took it I'll get around to putting it on in the next week or so if it works then I have my time and the $50 for the brake booster pump and then that whole car is in very nice shape with leather interior and it's battery is working and doing fine It just needs to be driven it's that green color this is the one I can't get the title for but I don't care about that makes no difference here I can put it in rotation and put whatever tag from another Gen 2 on it whenever I want to drive it It's on my insurance so financial responsibility isn't an issue and where I live cops don't really care about license tags other than something's hanging out back with a number on it.
  8. bisco
    52,894
    welcome!
    how long in years and miles would you like to keep it?
    how large is your repair budget?
    have you checked underneath for rust?
    can the 87,000 miles be confirmed?
  9. Leadfoot J. McCoalroller
    8,293
    7,809
    Pennsylvania
    2018 Prius c
    Get out while you can.
    These are sophisticated cars with the potential to go full money-pit when they get old, and a 2007 counts as old.
    The off-brand battery with a transferable subscription deal screams red flags to me.
    It really comes down to what you want: if you want a fixer upper Prius, the low miles on this one are appealing. It's just that you're very likely to be doing a lot of the fixing upping.
    If the point is to have reliable transportation with few dollars spent, there are better ways. Many better ways.
  10. PriusCamper
    13,475
    5,441
    Why even participate in our community if you're gonna give this kind of advice? Wouldn't your time be better spent doing something else?
    Gen2 Prius, regardless of repair needs, once fixed, are the simplest and most reliable hybrid car you can buy! What's more this website can walk you through every possible repair that needs to be done.
    #10 PriusCamper, Dec 10, 2023
  11. PR122
    PR122 New Member
    North Carolina
    Thank you everyone for your responses!!! I was worried that I wrote so much that my post would be passed over, so a big thanks to all of you for taking the time to read. It means a lot. :)
    The car needs the combination meter repaired, which we had factored in the purchase price, so that was acceptable. However, it has never had an ABS or brake booster repair/replacement (still not sure if replacing the ABS fixes the brake booster, or if these are two different repairs?), but it is making random noises when the brakes are held, so something is happening there. And then, from replies, it sounds like the hybrid battery could be the reason it is sluggish. Alternatively, it was suggested to me that the catalytic converter that was replaced could be the cause, so might need work or a replacement there. All this is sounding like cha-ching cha-ching $$$ especially when money is limited and I was trying to buy a vehicle that was in good shape to drive, not a project.
    The majority of you are saying to move on to something else, that this car will end up being costly for me to maintain, and I think I agree with you. I knew some things about the Prius before, but now that I have had a little time with one (and heard some odd noises that knew nothing about prior to hearing them which caused me to research and learn even more), I do believe this vehicle is beyond both my financial and DIY means. I am not mechanically inclined, and generally send my car problems to a garage. I was intrigued by all the reports of people DIYing much of their Prius repairs, but I have some health problems, so other than some of the smaller projects, I mostly dream about doing them but honestly think I would more likely have someone with some genuine skills and experience do most of the work to reduce the risk of making even more costly mistakes.
    I genuinely appreciate all of you for validating my concerns whether you were for or against me purchasing the vehicle. My husband told me that i was stupid and crazy, that I should just keep the car, that I didn't hear anything, and that I didn't know what I was talking about - and I don't, I truly don't, but we are splitting (refer back to the insults and gaslighting), and my money is very limited, so I need to be very careful with what I purchase, so will probably chose something that isn't a hybrid going forward. It would be one thing if I had owned the car for years and it was paid off, and I was simply having repairs done to maintain it - but I think it is too much to purchase it AND have to do a lot of costly repairs in the near future. If I factor the purchase price plus the cost of those repairs and a battery, etc, my vehicle purchase choices open up quite a bit. I still don't want to spend out all that much, but I think I will go a little higher to buy a standard vehicle that would be more reliable.
    Thank you all so much for the replies! :)
    JohnPrius3005 likes this.
  12. Tombukt2
    13,875
    2,521
    Durham NC
    Yes it will be costly initially that is probably a fact with the things that you're mentioning and if you can't do any of it then it's even more expensive when you look at what it will cost for a Toyota Yaris say a 2009 with 150,000 mi on it you would be much better off with that and be able to drive it any way you want to including not driving it without any consequence when you walk up to it it will start and drive and easily get 30 plus miles to the gallon It's not worth it for your situation to spend more money to get a few more miles to the gallon when most people in reality are trying to get out of their car not stay in it for extra miles most people today are trying to get out of the car ride their bike whatever be outside more whatever the situation is drive their kayak to the river so they can be in the boat right only youngins want to spend all their time in the car delivering for Domino's Pizza for the most part. The Yaris basically is a Prius without the battery and the funky transmission with the electric motors The reliability of a Corolla with a great engine It's just a decent all around setup to some people that's kind of funky looking I would take the Yaris over the Honda fit any day That's just me I like the 1N engine. Until it got updated for use in the Prius c then it becomes like the 2Z and probably not really worth your time.
