2007 Prius Tapping - timing chain or rod knock? (how to test?)
Discussion in 'Gen 2 Prius Technical Discussion' started by JoeVR, Aug 19, 2025.
  1. JoeVR
    JoeVR Junior Member
    23
    Midwest
    Hi all,
    I have a 2007 Prius that just rolled over 250K last week. It's been a great car, and I have maintained it regularly. I change the oil every 5k miles with Mobil 1. At the last oil change, I noticed it had gotten really low on oil, and started to develop a tap-tap-tap while driving. It is more pronounced now, but still runs and drives great.
    The dealership said it was a deep rod knock (spun bearing) and that I needed a replacement engine.
    However, this dealership is notorious for bad/incorrect diagnoses, so I wanted to ask the Prius world out there if there was a good way to test this on my own. I realize I may be facing an engine swap, but if I could get away with just a timing chain replacement or something else, that would be great.
    I have a mechanic's stethoscope. What should I be listening for here, or what else should I be testing? The oil looks clean.
    Thank you!
  2. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    From under car you want to get on side big block car running and listen then have some one step lightly on gas whilst ya listen at area on block wer a rod is . Obviously you gonna be doing this at different places on side o block . You will isolate . Drive it till it snaps . It mite be a long time. Keep it full of oil . I'm 20K changes making 500K pretty easily in SE heat good luck
  3. T1 Terry
    T1 Terry Senior Member
    967
    547
    My taxi Prius was diagnosed with the same thing, turned out to be a block cat, the knock only occurred under load and it progressively worsened till I relented and changed the timing chain ..... it wasn't "AS NEW" but it wasn't worn to the stage the tensioner wasn't taking up the slack .....
    Test drive, still the same. Turned out the blocked cat would build up so much pressure the exhaust header pipe would compress the springs that hold is to the cast manifold, the gas would escape and the pipe would hammer back onto the manifold .......
    Fitted an aftermarket cat and a new fuel filter ..... went better than ever and was still going great when I took it off the road at 750,000 plus kms
    T1 Terry
  4. JoeVR
    JoeVR Junior Member
    23
    Midwest
    Thank you both for the replies.
    It’s funny that you mentioned that, Terry, because I had gotten a P0420 CEL for the catalytic converter right before the tapping started. But then I started running premium gas in it, and after the second full tank of 93 octane, the CEL went away. I wonder if the cat is the problem here.
    I will put the vehicle on a friend’s lift to see if I can see or hear anything more detailed here - how do I check to see if the catalytic converter is the problem? The one I replaced 60k miles ago was a Walker with a 25k mile warranty.
    thank you!
  5. JoeVR
    JoeVR Junior Member
    23
    Midwest
    I also wanted to add that I live in a county that has no emissions or Inspections.
  6. T1 Terry
    967
    547
    Take the cat off and look inside from the engine side and look for any clogging of the membrane ..... it will be obvious if it's blocked or not .......
    If it is blocked, try gently tapping a piece of pipe the will fit inside the cat pipe ..... till it appears at the other end, cut off any excess and refit the cat ..... has the problem gone away?
    This is just a down and dirty test method to confirm that is the only problem ..... I'm not suggesting you should leave the cat neutered ;):sneaky:
    T1 Terry
  7. JoeVR
    JoeVR Junior Member
    23
    Midwest
    Thanks, everyone!
    I managed to get underneath the car and with a mechanic's stethoscope figured out it definitely appears to be a lower end knock.
    Our local salvage yard had an engine with 85,000 miles available for $500, so I just decided to buy it. Since it's still driving just fine, I am going to keep the Prius going until the weather cools down and I'm going to do the swap!
    Terry - thanks for the advice - when I go to do this swap, I'll check out the catalytic converter and see if it looks blocked.
  8. JoeVR
    JoeVR Junior Member
    23
    Midwest
    Hi everyone,
    Just a quick update here. I ended up doing the motor swap successfully, and I've put about 600 miles on it already with no problems.
    I tore down the bad motor to see what had happened.
    Turns out one the piston skirts had broken off and was laying in the oil pan. I can't believe I drove this car for around 7,000 miles with a broken piston skirt. Here are some photos:
    thanks everyone for your support in this
    VelvetFoot likes this.
  9. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    Original manufacturing issue?
  10. Tombukt2
    13,845
    2,515
    Durham NC
    Maybe possibly an original manufacturing issue I kind of doubt it and long as it breaks below oil ring it might gone longer
