2007 Prius - That age-old HID issue...
Discussion in 'Gen 2 Prius Technical Discussion' started by cwoodr91, Jul 10, 2015.
  1. cwoodr91
    cwoodr91 Junior Member
    Boston
    Hi there,
    I've got a 2007 Prius Touring and have been experiencing that well-documented issue with the HID. Namely, the driver side cuts out after a few minutes of being on. If I flip the lights off and on again it will come back, but will inevitably go out again.
    Last summer, I removed the assembly and dumped out about a half a cup of water, and drilled a small hole to create air circulation to dry it out completely. That didn't solve the problem so I did more research. I just replaced the ballast (which was corroded as hell), and that didn't solve the problem either (to my great disappointment). I found a salvage yard that has the whole assembly from a 2008, and I'm about to try that. If even that doesn't work, then I guess it has to be a shoddy power supply from the car, correct? And, in this situation, what can be done, if anything?
    Has anyone else had this issue to this extent? All I've been able to find are folks who replaced the ballast, or who fell into the extended warranty period that Toyota so graciously enacted back in 2011 (needless to say, my car does not meet their criteria anymore).
    Thanks!
    Chris
  2. Patrick Wong
    18,213
    6,529
    I think that it is more likely that the HID bulb needs to be replaced.
    The ballast is the high voltage power source for the HID bulb.
  3. Bill Gibson
    Bill Gibson Junior Member
    NORTH CAROLINA
  4. Bill Gibson
    NORTH CAROLINA
    What did you find out? Did you fix this problem and what was the fix?
  5. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    After having the first problem with the lights in January I discovered I had water issues as well. Fortunately there were no signs of corrosion or rust but I bit the bullet anyway and preventatively replaced the driver's side assembly, bulb AND ballast with OEM parts all at the same time. It's only been a few weeks but so far, so good. If it acts up again I'll take a serious look at an HID to LED conversion.
    Chris, if there was a lot of corrosion around the ballast is there an easily visible way to replace or splice wires around the ballast connections? The corrosion may have extended into the surrounding area.
    #5 srellim234, Feb 21, 2018
  6. Bill Gibson
    NORTH CAROLINA
    I've seen so many issues with the fix for the 2007 Prius, and since I'm not very good as a fix-it guy, I went to Fred Anderson Toyota on Glenwood Ave. in Raleigh, NC and paid them $482.09 to change the two HID light bulbs. I did that on 3-08-18 and so far they're working fine.
    srellim234 likes this.
  7. Bill Gibson
    NORTH CAROLINA
    10-13-19 and still doing fine.
