2007 Prius - To Flush or Not to Flush Brake Fluid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sdrocker, Jul 20, 2018.
  1. sdrocker
    sdrocker Member
    166
    San Diego
    I'm thinking of flushing my brake fluid. I have the techstream mini vci tool. I've read some people say it's a bad idea unless necessary due to actuator failure. How do you tell if it's necessary?
    For reference I have attached photos I just took.
    I don't know if this vehicle ever had a brake flush done but I've had it since the beginning of 2015. It had 163,000 miles then and has about 201,000 miles now.
    Any advice? I already bought four 12 FL Oz bottles from Toyota late last year but never got around to doing this until now. I imagine I didn't buy enough fluid to do the entire job and I also don't think I can return them either. Hmmmm.......
    I remember some people quoting toyota recommends replacing every 3 years.... is that old and bad recommendations from Toyota? hmmmm
  2. JC91006
    16,470
    8,383
    Unless you're having braking issues, I would leave it alone
    edthefox5 and m.wynn like this.
  3. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks. Mainly to reduce chances of messing up the actuator?
  4. JC91006
    16,470
    8,383
    Correct. You're in California, not much moisture in that fluid.
    If that's a concern for you, there are test strips you can buy to test the fluid
  5. sdrocker
    sdrocker Member
    166
    San Diego
    Got it.. even if its the original fluid? just checking. I can't find any brake flush in the paperwork the previous owner left me..... I spent $43 on four bottles of Dot3 from Toyota.. kind of annoying... wonder if I could save it for later sealed....
  6. JC91006
    16,470
    8,383
    $43 for brake fluid? I didn't know they cost so much now.
    If you keep your car long enough, the actuator may fail and you would need that expensive fluid
  7. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Should flush every 3 years or less, Toyota dealer for the prius should do It, silly, but a money saver.
  8. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks.... I thought the same but others have reported on here its better to leave it be..... i just past three years since I bought the car with an unknown service history so i was thinking of doing it myself since i bought the toyota brand dot 3 fluid and have the techstream mini vci tool... it seems its a debated topic. hmmm.
  9. ChapmanF
    15,111
    You can squirt some out at the bleed screws and use some brake fluid test strips. The lines to the wheel cylinders are dead ends, so the fluid that's down there has been stuck there forever and exposed to the most heating. If it's ok on the test strips, chances are very good it's all ok.
    -Chap
    m.wynn likes this.
  10. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks, I put the wheels back on. It stops fine... the longer I keep this car the more embarrassment I have to endure.. maybe not worth the hassle to change the fluid or put it back on stands and use test strips... ;-) I'm hoping to get a toyota tacoma next car...
    #10 sdrocker, Jul 20, 2018
  11. JC91006
    16,470
    8,383
    Embarrassment? Like the paint work is ugly? Or the young women don't like it?
  12. sdrocker
    sdrocker Member
    166
    San Diego
    Haha, young women actually don't even seem to mind... its some of the guys at work... unfortunately they've seen my other ride which is an old school traditional custom 50's hotrod and I also have a 1966 c-10 truck so when I'm in the Prius I lose all the respect I had ;-)
  13. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    It's DOT 3 brake fluid. Flush it every 2-3 years...regardless what car it is or who makes it.
  14. ChapmanF
    15,111
    If there were no such thing as test strips, rules of thumb would be all we'd ever have to go on.
    -Chap
  15. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Are those your older vehicles also emissions complaint in California, or ?
  16. sdrocker
    sdrocker Member
    166
    San Diego
    True! I guess I can put it back on jackstands and mess around with it another weekend. Out of curiosity are the test strips ones from a particular company? Pheonix? I think I read about that in another forum or link to a website..... Not sure any of the regular test strips are fine. I'm aware Toyota uses Dot 3 but maybe their brand has more lubricant and the prius brake system is sealed better making the 3 year rule not as necessary for the prius?
  17. sdrocker
    sdrocker Member
    166
    San Diego
    Yes. I think older than 1977 ... or somewhere in the 70s you're exempt.... my 53' has glasspack exhaust and rumbles like an old school hotrod so if that exemption didn't apply i'd be in big trouble. My 66' C-10 has mufflers but they are old.
    Dxta likes this.
  18. frodoz737
    4,297
    2,347
    33
    Never understood why someone would ask a Doctor if they should smoke, then not take their advise not to. No...you will not die right away if you start smoking, but you will live longer and save money in the end if you don't...all things being equal. ;)
    Mechanic
  19. ChapmanF
    15,111
    My doctor sometimes favors a noninvasive test before recommending a procedure that could risk iatrogenic problems.
    -Chap
    Ianmeister likes this.
  20. frodoz737
    4,297
    2,347
    33
    That's right...how could I forget. When you use DOT 3 brake fluid in a Prius, it magically becomes lifetime fluid. :rolleyes:
