2007 Prius TPMS Woes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sdrocker, Feb 16, 2016.
  1. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    ...if you check MiniVCI Toyota on Amazon look at the highlighted negative review he shows how to check for bad solder joints and fix it. Although seems funny to have partially working VCI.
  2. sdrocker
    sdrocker Member
    166
    San Diego
    Wow that's interesting! And I literally gave away all my hot air rework soldering equipment a few weeks ago.. ahh!!! I also think it's weird it would partially work from bad solder joints.
  3. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    also check the other connections as he shows
  4. sdrocker
    sdrocker Member
    166
    San Diego
    Thanks taking a look now.
  5. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    I decided to order one of the 64-bit mini VCI so I gotta wait for epacket from China.
  6. sdrocker
    sdrocker Member
    166
    San Diego
    Oh interesting. Your's is a Gen 2 prius? If you can connect to the TPMS, I'll buy one just like yours.
    Merged
    EDIT: I just got back from the tire shop. 3 and a half hours of waiting.
    They told me they were going to try a different sensor. They did that and were able to reprogram it and now the light is gone. They didn't explain the difference between the sensor they put in on Tuesday and the sensor they put in today. Supposedly they had to order it and that's why I was waiting around for a while. I wonder if it came from Toyota hmm.....
    They also gave me a future free oil change.
    #26 sdrocker, Feb 18, 2016
    wjtracy likes this.
  7. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    apparently the denso on Amazon are a match to OEM
    sdrocker likes this.
  8. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    I say pass on free oil change. Expect long wait and the oil level to be overfilled. Worst case of an oil overfill, here on PriusChat, resulted in a used engine replacement.
    Acquire tools to DIY. I can do it in 30min, start to finsh w/ clean up. Rotating tires adds 15min.
  9. sdrocker
    sdrocker Member
    166
    San Diego
    True. I did the last two oil changes myself and am aware not to overfill. Quite possible they may do just that.
  10. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    OK I got mini VCI from China the 32 and 64 bit version for $39 bucks. Turned out my old computer was XP 32 bit, so I have not tried the 64 bit software install yet. 32 bit worked fine.
    Re; Techstream TPMS- I noticed there was input codes for 5 tires ID1 thru ID5 and ID5 was set for code 0000000 (which meant unused). So I reset the TMPS by entering 0000000 code for the bad TMPS (ID1 right front), thus shutting off the darn flashing idiot light. Next step I will buy a new Denso sensor from Amazon. I let a little air out of each tire to figure out which tire was which.
    #30 wjtracy, Mar 5, 2016
  11. genchau
    genchau Junior Member
    Los Angeles, CA USA
    2001 Prius
    Thank you @wjtracy that's the exact info I needed. I wanted to program 0000000 into one of the bad sensor last night but found out my mini vci lacked ecu programming functionality because it's v1.4.1. This version does not have k-line communication which is used for programming. I'm ordering a mini vci v2.0.4 on Amazon for $42 which should solve that problem and allow me to program tpms.
    I only have one bad sensor right now. I hope to buy a used one for $20 to replace it. Then I'll replace the battery on the bad one and save it until the next one goes out.
    wjtracy likes this.
  12. JC91006
    16,827
    8,600
    The 0000000 doesn't work if you drive more than 1 hour, the car's ECU will pick up the error again. Only works if you drive less than 1 hour and shut down
  13. wjtracy
    11,370
    3,608
    Northern VA (NoVA)
    Yes that post is a little old, setting to 0000000 seems to be a temporary reset.
    The following thread gives all the things I have tried:
    TPMS Management with Techstream | PriusChat
    Right now I finally lost my second TPMS unit at 12 years, so my warning light is back on. I probably need at least 2 new tires....if so I may finally replace all the old TPMS.
