2007 Prius w/ 240,xxx miles, red triangle. Help!!
Discussion in 'Gen 2 Prius Technical Discussion' started by Naskaf1, Aug 12, 2021.
Tags:
  1. Naskaf1
    Naskaf1 Junior Member
    Detroit
    Prius
    So, i filled up my tank today. After driving about 15 mins the red triangle, VSC sign, check engine light and exclamation point in a circle around a two brackets came on and on my navigation I see a red car with a red exclamation point thru it. The car is running fine. I did notice the AC would blow harder intermittently when i drive.
    I took the car to autozone to get the code read and he said
    P0420 is the catalytic converter code.
    I checked the engine oil its up to the first dot on the dipstick. All the fluids are full. The car is running as usual. Would the red triangle come on if it was only a catalytic converter code? Should i be concerned about a gasket issue since the AC was blowing harder sometimes?
    52,823
    triangle is a general warning saying: 'bypass auto zone, take me to a place with tech stream diagnoetic software (dealer or specialist) and read the codes and sub codes, then get ready for a large bill'
    all the best!(y)
  3. ChapmanF
    19,008
    Now that right there sounds like the exact kind of software I want!
    On a calming note, the Master Warning Light (the triangle) can come on for a lot of different reasons. Once you have noesis of why it came on, sometimes a large bill may be involved, but also it may be something quite simple to fix.
  4. Naskaf1
    Detroit
    So, i took it to a dealer and they said I need to change my inverter water pump and get a flush. Quoted me 900 dollars. I declined and bough OE parts from their store. They charged me 60 bucks for diagnosis.
    As i was leaving, all the dash lights were gone, did they reset all the lights? Will the red triangle come back again?
  5. bisco
    52,823
    could you have possibly over filled the tank?
  6. bisco
    52,823
    yes, they will come back on
  7. Naskaf1
    Detroit
    I was at E and it was blinking. I filled about 9.5 gallons.
  8. bisco
    52,823
    60 is a good price for a diagnosis. ask them for the codes
  9. Naskaf1
    Detroit
    Would you let a local mechanic replace the inverter pump? My local mechanic said 100 dollars. I have my own OE parts
  10. bisco
    52,823
    absolutely, very easy job
