2007 Prius Warning Lights - Weather or More Systemic Problem
Discussion in 'Newbie Forum' started by SeptupleWhammy, Jan 31, 2019.
  1. SeptupleWhammy
    SeptupleWhammy New Member
    Hudson Valley NY
    It was pretty cold this morning, though car is in insulated garage. I’ve attached images with the lights that alit on my dash this morning. Not sure if this is an overreaction to below zero temperatures or indicative of a more systemic problem?
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Seems like a lot of people are having problems this week. Honestly you are going to have to provide more than a picture of the dash lights for any kind of answer. How does it run? Any codes? Check the oil lately?
  3. SeptupleWhammy
    Hudson Valley NY
    It seems to be running normally but I just took my girlfriend’s car to work instead. Not sure what you mean by codes but I had the oil changed about four weeks ago. Shouldn’t be a problem.
  4. SeptupleWhammy
    Hudson Valley NY
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    The car knows something is wrong, and lit up the idiot lights to tell you it knows something. Posting a picture of those dash lights is like saying "hey I've got a piece of mail for you" and then sending a picture of the envelope. You need to read it with a code reader.
    It could be anything.
    In super cold temperatures assuming everything else was perfect, the most common culprits are a misfire because of a bad coil or plug or o2 sensor. But you don't have a brand new car so it could be anything. The car knows what it's trying to tell you.
    Data Daedalus likes this.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    See post 7 on this thread:
    Just Another HV Battery Thread and Experiments | PriusChat
    I think your dash looks identical. Keep in mind there could be other issues that may cause the same indicators to illuminate.
    Odds are good the cold has something to do with it. Whether it's now a permanent, semi-permanent or temporary situation? Who can say until it warms up.
    When it gets super cold and something fails, sometimes getting warm again doesn't matter.
  7. Skibob
    2,912
    1,505
    Northern California
    When those lights are lit the computer logs codes about what it thinks is wrong with the car. You need to read the codes to have any chance of getting help here. Preferably with a code reader that can read Toyota specific codes, not a generic OBD2 reader.
  8. padroo
    padroo Senior Member
    2,763
    2,253
    Always close your doors when you take pictures of the display.
    Data Daedalus and Skibob like this.
  9. Skibob
    2,912
    1,505
    Northern California
    Classic. LOL.
  10. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I’m thinking the 12v Battery is old and has reacted to the severe drop in temperatures. The first time my 2nd Generation Prius malfunctioned, this was the reason why. Intense cold and a 6 year old 12v Battery.
    Self diagnosed by perusing Prius Chat. Had a new one installed at Toyota, all symptoms disappeared. That was 5 years ago.
    Most likely to be the cause of your problem.
    iPhone 6s +
    Raytheeagle likes this.
  11. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    ALL vehicles tend to show their rear (impending issues) when extreme conditions are encountered.
