2007 Prius Warning Lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ingyaningya, Feb 20, 2016.
  1. ingyaningya
    ingyaningya Junior Member
    70
    17
    Miami
    Whenever I push the break down and press the power button (putting it into READY mode), yellow warning lights show up on the dashboard (such as ABS, brake, etc.) for about a second or two, then disappear when the car is ready to drive.
    I went to a mechanic and they told me that this is normal, and that I should only worry if those lights stay on and don't turn off.
    I just wanted to know from fellow Prius drivers if the mechanic's statement was correct and that this is normal and that I indeed should not worry.
    - Also, they 12v battery was tested and it came out as 12.5v
    #1 ingyaningya, Feb 20, 2016
  2. Patrick Wong
    18,210
    6,514
    Your car is exhibiting normal behavior.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    The warning light come in briefly to confirm for you that they are working, and not burnt out. You should be concerned if you don't see them in startup.
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    You appear to be new to owning a Prius. Do yourself a favor and read the owners manual in its entirety. If the manuals are missing, you can download it from Toyota.com, Owner section, as a PDF.
    Get into the habit of checking the oil level on a regular basis as well.
  5. Eddy Barrios
    Eddy Barrios New Member
    Guatemala
    Don’t worry, is normal initialization on Prius, mine is 2008.
  6. bisco
    52,547
    its a self check. and if you haven't by now, replace the 12v
  7. dolj
    dolj Senior Member
    8,610
    4,370
    Wellington, New Zealand
    Replacing the battery just because is a hugh waste of resources. Replace it if it fails testing, otherwise, leave well alone.
