2007 Prius will not start and other issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by bigsamthered, Aug 7, 2025.
  1. bigsamthered
    bigsamthered New Member
    Georgia, United States
    I picked up a non-running 2007 Prius with 153k miles for cheap and I'm attempting to get it working properly. I don't have much history on it - the seller bought it from his next-door neighbor's estate sale. He said he drove it home just fine and after he parked it, the brake warning light came on and it never moved after that. He stated that at that time, the only light on the dash was the brake light. He did a very little bit of troubleshooting before selling it. He stated it sat for about 6 months before he sold it to me.
    Now, a bunch of lights are lit up on the dash (red triangle, check engine, ABS, etc). I got the Dr. Prius app and it's showing codes P3000 and P0AFA (it also showed P0A84 but I cleared that one after replacing a blown fuse for the HV battery cooling fan and there was one for the battery disconnect not being locked in properly and I cleared that one too). When attempting to shift from park, I get a continuous beep and it will not go into gear.
    The Dr. Prius app shows that the HV battery is at 149 V and shows that blocks 1-4 have negative voltage. In the notes it says that all 14 are suspected to have problems. Can a weak battery prevent shifting into gear?
    The parking brake switch was bad/going bad (open circuit all the time - I don't think this would explain the brake light staying on) so I replaced it, and the brake pedal switch was also going bad (open circuit on the small wire when the button was pressed) so I replaced that one too. I had some time the other day so I checked every relay I could get my hands on and they are all functioning properly. The brake warning light persists and it will not shift into gear.
    The 12 V battery was replaced in May of this year and has 13+ V. I can hear the brake actuator pump operating and the brake pedal feels fine. Plenty of pad left.
    In addition to the above issues, I have noticed the following:
    Touchscreen display doesn't come on
    Electric door locks do not work using fob or switch. Fob turns security system on/off but locks don't respond. The locks work when manually actuated on the door.
    Headlights don't come on (running lights and brake lights work).
    Rear hatch won't open with the button on the handle - has to be manually opened from the inside.
    A/C fan blows but compressor doesn't come on (I have done 0 troubleshooting for this).
    The car seems like it's been taken care of - clean engine oil, air filter, new tires, etc.
    What should I check next? I called my local Toyota dealership and they said they could charge a HV battery but won't - they will only replace it unless it's a warranty claim and the warranty company says to do it. My concern is that I could spend thousands replacing an HV battery just to have other issues that prevent it from operating properly. I got it cheap enough that HV battery replacement would be worth it to me, if that's what it needs.
  2. pasadena_commut
    pasadena_commut Senior Member
    3,072
    956
    Southern California
    If that is the original battery it shouldn't be expected to work at that age.
    Besides the probably failed and definitely discharged HV pack, there seem to be an awful lot of electrical problems on that car. Both brake switches going out at the same time? That doesn't sound likely at all. Check for signs of flood damage. If it has that sort of damage walk, no, run, away. Might be worth it to run a CarFax to see if there registration history matches the seller's description.
    If no evidence of flood damage, start with the headlights. HID or Halogen? Hopefully the latter because that is a much simpler system. Figure out why that isn't working, perhaps if fix that it will also take care of some or all of the other electrical problems. I would suggest keeping the 12V on a charger and NOT trying to start the car, just press the power button twice to (in theory) turn on all the electrical parts you listed which are not working.
    #2 pasadena_commut, Aug 7, 2025
    52,904
    you need a prius aware scanner. tech stream is best, but you can try autel 200.
    your car is a mess and the seller was most likely lying, but 6 months of sitting can wreak havoc on a hybrid battery.
    once you have the proper trouble codes, you can decide if it is worth repairing.
    did you check the 12 volt with the car off? 13v is a bit high, even for a new battery. you should get a free load test an an auto parts store.
    all the best!
    Brian1954 likes this.
  4. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I have the same issue, new 12v battery last spring. It was working fine until today, the only change was the below zero temp. It is garage kept and the garage temp is about 20 (f). 2008 is a backup car with 165K I will look at it when it warms up a bit. Hopefully it's not a mouse issue.
  5. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Problem SOLVED.
    It turns out my 9 month old 12 volt battery was shot. I was able to jump start it and take it to the shop that I purchased the battery from. They replaced it at N/C. :)
  6. notspam3
    notspam3 Member
    141
    76
    Toronto
    2024 Prius Prime
    XSE Premium
    Chipmunks ate my wires...did you buy my car from the wreckers?
