2007 Prius with C1259 and C1310 - any ideas?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by romanlutsk, Apr 7, 2016.
  1. romanlutsk
    romanlutsk Junior Member
    73
    Cupertino, CA
    2002 Prius
    I'm helping to fix someone else's 2007 Prius and after replacing 2 failed battery cells, cleaning the electrolyte leak (P0AA6 with 526 and 612) and putting in a new 12v lawn mower battery, the final codes (C1259 and C1310) still remain.
    The Techstream scanner doesn't report any subcodes (sometimes there is a blue snowflake symbol besides C1310, but when I double-click on it, it says something to the effect of "this DTC does not exist").
    I used the Exetech megohmmeter with 500V setting on the battery (but disconnected the battery ECU and other cables prior to the test, so I don't think I damaged the ECU).
    Here's the history of codes, as I worked on that prius, in reverse chronological order:
    C1259 - HV system regenerative malfunction
    C1310 - HV system malfunction
    P0AA6
    526
    612
    - cleaned the leaked electrolyte on the bottom of the HV battery case
    C1259
    C1310
    B1421
    P0AA6
    C2310
    C2318
    - replaced 12V battery
    P0A0D
    - push the interlock (service plug on the hybrid battery) down
    C1259
    C1310
    B1421
    - found two low voltage cells and replaced them
    The engine starts, but the red triangle, VSC, check engine and other lights come on.
    I've charged the new battery completely, tried clearing the codes (but they come back right away), any ideas what else I could try?
    Thanks!
    #1 romanlutsk, Apr 7, 2016
  2. romanlutsk
    73
    Cupertino, CA
    2002 Prius
    Mystery solved. It turns out that a nut on one of the cell terminals in the HV battery (the one with the sense wire) was missing, so the HV battery ECU couldn't get a good reading of the voltage.
    I put a nut back on, cleared the codes, restarted the car a couple of times and the errors are gone for now. Hopefully it stays that way.
    Mercedes Blake and bisco like this.
    51,082
    well done!(y)
  4. Mercedes Blake
    Mercedes Blake New Member
    Sacramento
    How much did all of this cost you? The same lights are on my car with codes P3014, P3000, C1241, C1259, C1310. I was told I could replace 6 parts that are inside the battery which cost about $30 each part but I’m still unsure of what exactly is going on. Do I need to buy a whole new battery?
  5. bisco
    51,082
    you don't have a failed battery code. perhaps the bus bars and etc. are corroded.
  6. dolj
    dolj Senior Member
    8,194
    4,175
    Wellington, New Zealand
    Actually there are two codes that indicate the battery is not really happy:
    P3014 = Battery Block 4 Becomes Weak
    P3000 = HV Battery Malfunction
    Not sure what "6 parts" they had in mind, but you likely need only one or two modules replaced. In addition, like bisco said, you will more than likely need the bus-bars cleaned as well.
    If you want another 10 years reliable use of your car, and it is in otherwise excellent condition, you should consider just replacing the whole battery with a Factory OEM new battery, and not a secondhand battery of any description, which includes descriptions such as "rebuilt", "reconditioned", etc. If it would not make sense to put in and OEM new battery, then you should rework the battery yourself. If you are not the DIY type, @JC91006 or @TMR-JWAP may be able to recommend a place where you could have the work done. TMR-TWAP might even have a solution to offer you.
  7. JC91006
    16,670
    8,516
    If you have a good condition, low mileage car, I would recommend you buy a new battery and forget about it. This is the most reliable option. You can also try and request a good will warranty from Toyota to get your battery replaced
    If you have some issues, high mileage, and need to buy extra time before getting another car, then you should repair the battery and not buy new. This option is not very reliable but it's fairly affordable. And there are even members in your neck of the woods (northern cal) that can help with this option. @SFO @Raytheeagle
    Maria Camille, dolj, m.wynn and 2 others like this.
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    @Mercedes Blake , welcome to Prius Chat (y).
    Some questions:
    • How many miles on your Prius?
    • Original owner, or how long have you had this Prius?
    • What condition is the Prius in?
    • Any recent maintenance performed?
    If you can provide more details, I can probably help out:).
    Good luck and keep us posted (y).
    dolj, m.wynn and SFO like this.
  9. Gypsy62
    Gypsy62 Junior Member
    38
    North America
    Nice escape!
    If, by chance, you took a pic of the location of the terminal with the missing nut that would be useful.
    Cheers
  10. JC91006
    16,670
    8,516
    I think it's any of the 28 modules, 1 missing a nut
  11. Gypsy62
    38
    North America
    OP wrote: "It turns out that a nut on one of the cell terminals in the HV battery (the one with the sense wire) was missing"
    As a newbster, his reference to "the ONE with the 'SENSE' wire" means nothing to me, so I was hoping a pic could illustrate which cell/block has this 'sense' wire.
  12. JC91006
    16,670
    8,516
    You can't have any missing nuts, regardless of its location.
  13. Gypsy62
    38
    North America
    So when the OP said
    "It turns out that a NUT on one of the cell terminals in the HV battery (the one with the sense wire) was missing"
    maybe they were referring to a 'wire' nut and not a 'mechanical' nut?
    Just trying to get clarification...
    Thanks
  14. JC91006
    16,670
    8,516
    edthefox5 and Raytheeagle like this.
  15. Alam
    Alam New Member
    2016 Prius v wagon
  16. Alam
    Alam New Member
    2016 Prius v wagon
    I have a code p0a80 I checked all the cell all of them 8.11v and up to 8.34v . This is 2015 Toyota Prius V can you please help me out
  17. bisco
    51,082
    you need to test them under a load. how many miles on her?
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    There are usually other codes associated that will also point you in the right direction ;).
    What scanner are you using?
  19. Dom06
    Dom06 New Member
    Georgia
    I’ve had the same issue on my ‘06 Prius (1310 & 1259 codes) but I just disconnected the 12V battery for about 10 minutes and that cleared the codes and it’s starting again. Anyone else have any luck with this? I’m a bit nervous now.
  20. bisco
    51,082
    that just resets the codes, it will be back
    Skibob likes this.
