2007 Prius won't light up
Discussion in 'Gen 2 Prius Technical Discussion' started by SBP Mike, Apr 24, 2025.
  1. Mike SBP
    Mike SBP New Member
    Chehalis WA
    changed my email recently too. Interesting bit of info: I used dual chargers, one on the big battery cranking out 255v and a 12v charger set on 50 amp start setting to turn on the lights
  2. dolj
    dolj Senior Member
    8,654
    4,404
    Wellington, New Zealand
    Why do people create a new account rather than use the Forgot Your Password option?
  3. PriusCamper
    PriusCamper Senior Member
    13,472
    5,440
    Pacific Northwest, USA
    Usually because they think its less effort and the old account isn't much different to them than a new account.
    How many amps you use to top off and balance hyrbid battery pack? Do you run the cooling fan when you do that?
    #43 PriusCamper, Oct 10, 2025
  4. pasadena_commut
    pasadena_commut Senior Member
    3,071
    956
    Southern California
    I am really confused by the second part of that statement. What model 12V charger is that?
    Sending 50 amps at "12V" into a 45Ah S46B24R battery is about 12.5X higher than the maximum charging current that type of battery should ever see, and will likely "put out its lights", permanently.
    Doing the same thing to a HV pack module would destroy it in short order.
    Is this 50A charger used to power up the car's 12V system instead of the 12V battery or the DC-DC converter in the inverter? There are some procedures that can take a long time and the battery can run down, and one might use a charger designed for this function in that case. That would make a lot more sense. For instance, the PRO-LOGIX PL2320 has a setting for that. However, it just has a "power supply" setting and the current cannot be set separately (it supplies up to 20A). True adjustable power supplies (sometimes referred to as chargers) can (sometimes) be set to 50A. Setting a 50A current limit would be fine. Setting a 50A forced current (sometimes an option, and then let the "12V" voltage vary) would be bad, very bad. I have also seen chargers with a 50A "engine start", but that's for vehicles with starter motors, which the Prius does not have. I don't think chargers in "engine start" can maintain the 50A for very long, probably just a few seconds.
    PriusCamper likes this.
  5. Mike SBP
    Mike SBP New Member
    Chehalis WA
    that combination of chargers overcame the reluctance to come to life. I think that would be an important combo charger setup to share with other folks who are trying to revive a very dead prius.
  6. Mike SBP
    Mike SBP New Member
    Chehalis WA
    just used the 255v ballast charger to bring voltage up. Used a 12v charger that has a "start" setting. Both were only on for the time to hit the power button and get everything going. Then I disconnected both chargers and took the car for a drive. No cooling fan required for that period of time. I have watched the ballast chargers in the past, they don't cause much heat buildup very fast. Yes, use cooling fan if you are going to use the big battery chargers to "condition" the battery.
    Yes, what you said. only using the 12v charger in engine start mode for the time it took to hit the power button and have everything light up and hear the ICE get going.
    #46 Mike SBP, Oct 11, 2025
  7. pasadena_commut
    3,071
    956
    Southern California
    So, in "engine start mode" the 12V charger could supply up to 50A for a few seconds and that got the car started, but a 12V battery will still not provide enough juice to get to READY? That would imply the car needs an abnormally high amount of current to start.
    Is that all correct?
    Normally it takes something over 20A for a second or two to READY and a 12V battery can provide that. It can probably provide 30A even and keep the voltage above 11V. Maybe not 40 A though and certainly not 50A, which would be over 1C on a 45Ah battery. That would drag the battery voltage down to 10V or lower and the computers are not happy in that range, so no READY.
    This implies that there is an immense current drain somewhere in the 12V system, 10A or 20A or something like that above the normal draw. At least at startup, and probably after as well. Once the car is going the DC-DC converter can put out I don't recall the exact number, but something like 100A. So it can feed that beast. 10-20A is a lot of current to be mysteriously missing, let us all hope and pray that this is something like the rear defroster being always on, or the headlights always on, and not some short to ground. Because the latter could get very very hot. I would not drive this vehicle until that large current loss is accounted for.
    I would be very curious what the voltage is on the 12V battery (or at the jump point) when the car tries to start - and fails. Press the POWER button with a foot on the gas while somebody else watches the voltage. How low does it go? (My guess is that the car is designed to "give up" after a few seconds. The battery voltage will take a while to return to its resting value, easily 5 minutes, although most of the way there in 2 or 3 minutes, that is normal.) If the OP has access to a clamp DC ammeter it would also be useful to know what the peak current drain from the battery at (failed) startup is. I guess that would actually be "near peak", because the multimeter will only be giving 3 values a second, or something like that, so it will likely miss the real peak. The same device can be applied to the lead from the 50A charger when it successfully starts the car. (Perhaps the charger has a display mode where it shows output current? Some do. That way the clamp ammeter wouldn't be needed.)
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    A very discharged AGM battery has low resistance and can draw 70+ amps (for a short time) if you put a booster on it.
    Yes, slow charging at a low rate is the "best" way to go, but if you try to jump start it, you'll need lots of amps to do it .
    Brian1954 and PriusCamper like this.
  9. PriusCamper
    13,472
    5,440
    This is an eye opener that explains much... Is it possible that an ideal way to handle a discharged AGM is a high amp pulse followed by a steady charge, followed by a screen indicator on the device charging it that it's ready for operator to start the car?
    Does anyone sell a device like that? Hope so, at least one day.
  10. pasadena_commut
    3,071
    956
    Southern California
    The OP had swapped a known good battery (presumably charged to a reasonable level since it came out of another car which was in active service) into the bad vehicle and it still needed all those extra amps to start. This after it wouldn't start with a new (and I think fully charged) AGM battery. If the AGM battery was the problem then it should have started immediately in both of these scenarios without the extra oomph. It did not.
    As for recharging a very discharged AGM battery, any charger one would use for that will current limit to its maximum rating, typically a small fraction of that 70A. Jump packs must have current limiting circuitry too to avoid burning themselves out. To see all of that huge current one would need to attach either an immensely large charger with a commensurately gigantic current limit, or an unregulated source like another battery. The latter approach is used pretty often to trick a charger into working on a battery that is below the charger's lower voltage limit. I don't know if that brief large current surge damages the battery even more than the deep discharge already has.
    I also don't have a good sense for how long that large current flows, but if I had to guess, it would be at most seconds. I think what would happen is that the current would rapidly put a base charge into the weaker battery and then the high current would force the voltage up to match that of the donor battery, whose voltage was in turn depressed by the outgoing current, until the two voltages matched at 10A or thereabouts, probably at a voltage corresponding to something well below 50% SOC. After many hours the final voltage is going to be less than that for 50% SOC because of energy conservation (that's all the energy that was in the system to start, assumes identical batteries) minus losses from resistance and so forth. Unless the weaker battery is actually damaged. If the weaker one has at least one shorted cell I wouldn't want to be anywhere near it since it might go boom.
