2007 Prius won't start, 5 orange dash lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Richard Williams, Apr 29, 2016.
  1. Richard Williams
    Richard Williams New Member
    Chicago
    I got in my car today, put the key in, put my foot on the break, and pressed the start button, but instead of starting up, the start button turned orange, and 5 orange dash lights came on in the lower corner. I tried persistently to start it, and eventually it did try to start the engine, which worked fine. I drove around the block and then parked to see if I was going to have the problem again. This time the problem was more persistent the car never started again.
    I'm working on get a picture added to this post, but here are the 5 orange lights that are on in the lower right corner of the display:
    From left to right: 1.) A car with swervy tracks underneath it, 2.) An exclamation mark with a circle around it, and another partial circle around that, 3.) the ABS light, 4.) the VSC light, 5.) the engine check light.
    I've looked on google for about an hour now and can't figure out what this configuration of lights might indicate. I was hoping it was just the 12v starter battery, which I've heard is prone to dying in Prii, but I'm starting to worry that's not the case.
    Can anyone give me a hint what those lights mean? I don't want to pay for a tow until I have some knowledge of what to expect, especially because I just purchased this vehicle from a dealership last Wednesday. :(
  2. JC91006
    16,933
    8,643
    when was the last time you changed the 12v battery?
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    Did the dealer give you a Carfax report? That'll tell you if a dealer replaced the 12V battery and when. Checking the voltage on the 12V system is an easy thing to do and should be done now. Search here for an easy way to do it using the MFD. The next diagnostic will require either getting it to the dealer or buying your own scan tool.
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    !2v might be good guess as sitting unused in lot for a while could run it down sort of common with Gen2.
    Good news so far is no Red Triangle.
    You want to read the codes with ODB reader to see if any diagnosis.
    Check for inverter coolant flow.
    The first light is the icy road thing (science here), then believe next you have Tire Pressure monitor, ABS, Vehicle Stability Control, and CEL. Unusual.
    If I thought the 12v had a chance to run down sitting in the lot, I might start there. The smart key system can be a drain after 2-3 weeks sitting. There is an ON/OFF switch to help maintain 12v on sitting.
    #4 wjtracy, Apr 29, 2016
  5. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Code reading options in my signature.
  6. bisco
    52,785
    welcome! how many miles on her?
  7. Stevewoods
    Stevewoods Senior Member
    664
    1,253
    where I am
    First:
    1) Register the car at www.toyota.com/owners -- You will need to enter the VIN -- it will give you a good look at all service performed at Toyota dealers (supposedly) and possibly services performed elsewhere -- should have done it before you bought it, but...
    2) Check the 12v. With luck, that is your problem. Simple to put in a new one, but the part alone is around $200.
    If a friend has a multi-tester, easy enough to test. Not sure if you can do the MFD test if you can't start the car? Anyone? You could always pull it and take to the dealer or a parts store and have them test it.
    #7 Stevewoods, Apr 29, 2016
