2007 prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by eepers, Jan 2, 2013.
  1. bisco
    52,855
    start by checking the 12v connections. especially neg to ground. then have it load tested.
    if that isn't the problem, hook up tech stream and read the trouble codes.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Does the digital clock light up when you press the power button? If that does work then you might have a problem with the speedometer (combination meter) due to bad capacitor. Also would check all fuses (both underhood and under dash fuse blocks-) particularly the AM2 fuse.
