2007 prius
Discussion in 'Gen 2 Prius Main Forum' started by Mehmet alb, Jul 14, 2022.
Tags:
  1. Mehmet alb
    Mehmet alb Junior Member
    77
    Turkey
    the one with the red sign in the picture is not blowing cold air from the floor, what happens? what is the name of the part that causes it? thanks for the 2007 prius
  2. Tombukt2
    Tombukt2 Senior Member
    13,853
    2,515
    Durham NC
    I'm not sure what you're meaning The part you circled in red is the vent when you push the correct buttons on the set on the display then air should blow out of that vent cold or hot and that's nothing to do with the floor you put the icons to blow on the floor on the master display now those vents do break. And on eBay you can find one made out of better material for the middle only the one you circled for $24
  3. Tombukt2
    13,853
    2,515
    Durham NC
    You see the circle at the bottom of the louvers of the vent moving that will stop air flow out of that vent Make sure that's open look carefully there's an icon on that half circle
  4. Mehmet alb
    77
    Turkey
    Resimdeki ikisi de esmiyor i click to touch the face when I touch it, the air doesn't come, the ventilation is open
  5. Mehmet alb
    77
    Turkey
    Dokunduğumda yüze dokunmak için tıklıyorum hava gelmiyor havalandırma açık
  6. bisco
    52,837
    does it come out of the other 3?
  7. Mehmet alb
    77
    Turkey
    ayakları üşüten kısma dokunduğumda dokunmatik ekranda yüz bakımı için yüze ver.he doesn't give a cold from the two in the picture. some of the others are giving
  8. Mehmet alb
    77
    Turkey
  9. bisco
    52,837
    i think you have a stuck vent door. big job, you have to pull the whole dash apart
  10. Mehmet alb
    77
    Turkey
    nasıl yapmalıyım? Yapacak bir videon var mı? çok teşekkürler
  11. Mehmet alb
    77
    Turkey
    how should I do? do you have a video to make. thank you very much
  12. bisco
    52,837
    best way is look at an online parts breakdown of the hvac system to see where the vents flow and where the doors are.
  13. bisco
    52,837
  14. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  15. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Unlikely if this helps, but does show what is possible when repairing a prius AC system.
  16. alftoy
    alftoy Senior Member
    1,132
    519
    Saskatchewan, Canada
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,113
    2,011
    NJ-USA
