(2007) Replaced coolant and inverter pump 3 times in past year, still not lasting
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mainestreamrob, Nov 9, 2022.
  1. douglasjre
    douglasjre Senior Member
    2,162
    714
    Null, NL
    They screech when dry. Is it? Fleabay and AMZN crap are fakes. Get OEM
  2. BiomedO1
    BiomedO1 Senior Member
    3,449
    1,795
    SacTown, Ca
    These are actually very good points. The inner layers of the hose could've partially peeled away or collapsing, causing intermittent blockages. It's rare, but it does happen.
  3. T1 Terry
    T1 Terry Active Member
    929
    478
    It is a common problem with ICE lower radiator hoses if the radiator is partially blocked.
    The manufacturer adds a wire "spring" inside the hose to stop it collapsing, but if the cooling system has been neglected, that steel wire rusts until it breaks, then the hose collapses under load .....
    T1 Terry
    Prius Newby likes this.
  4. Prius Newby
    Prius Newby Junior Member
    Montana
    This time I installed a genuine Toyota pump.
    douglasjre likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,034
    1,965
    NJ-USA
    Because it is most likely that the noise is not coming from the inverter pump.
    When you "start the car" (go to ready), the ECM runs the Coolant Heat Storage pump for 5-10 seconds to pump hot coolant out of the thermos tank and into the engine.
    That pump is mounted behind the tank in the left front corner (ahead of the tire) - very close to the inverter pump.
    It is not uncommon for the CHS pump to "squall or screech" when it gets worn. You might also hear it a few seconds after turning the car off. The sound can change with different ambient temperatures.
    Mine made noise for a couple years - I eventually got tired of it and put a new one in.
    An easy check - press power button 2x without stepping on the brakes on a "cold" morning. The car will turn "ignition on" and run the inverter pump - but won't go ready and won't run the CHS pump. See if it still makes noise.
    #45 mr_guy_mann, Aug 18, 2025
    gdanner likes this.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,579
    764
    Southern California
    Lower the front part of the plastic shield which goes around the driver's side front wheel well and it will reveal the bottom of the thermos and this pump.
  7. Prius Newby
    Montana
    I think you are correct, thanks very much!
