2007 SKS Unlocks/Locks Erratically
Discussion in 'Gen 2 Prius Main Forum' started by CaseyH, May 27, 2019.
  1. CaseyH
    CaseyH New Member
    Washington
    Hello and thanks for any future help! My fiancé has a 2007 Prius with the sks functionality. After a traction battery failure and replacement at around 200,000 miles the car began to unlock/lock remotely itself as if you were using the sks but regardless of how close you are not. We will be sitting at dinner with the car parked down our driveway and still hear it go off. It is driving us insane! Lol. I have replaced the batteries in the fob, which didn’t affect it at all. Also, we have turned the SKS system off entirely and it still continues. Sorry if this is a newbie topic or easy fix but any help is much appreciated!
    51,076
    welcome!
    may not be the issue, but start with the 12 volt battery health
  3. JC91006
    16,670
    8,516
    Sounds like you have a sticky button on your keyfob. It has nothing to do with SKS
    51,076
    would that be the case if it is out of range with sks shut off?
  5. JC91006
    16,670
    8,516
    The sks shut off is the key information provided. So it's not sks related. It's just the button on the keyfob being pressed
  6. bisco
    51,076
  7. CaseyH
    CaseyH New Member
    Washington
    Got the replacement fob “case” off of amazon and switched the guts over to the new one. Works great! Thanks everyone for the help!
    WilDavis and Skibob like this.
  8. JC91006
    16,670
    8,516
    Make sure you switch over the RFID chip, most people miss this when they switch things over. It's the chip needed to start the car in the key slot
    Skibob and WilDavis like this.
  9. Vicki1959
    Vicki1959 New Member
    Mechanicsburg PA
    I'm new so cannot start a new thread. My 2009 gen 2 Prius frequently locks spontaneously, even when the key FOB is in the car. Very annoying when I set my purse on the seat then go to open the rear hatch and the car locks with my cell phone and key inside! New key FOB batter and the 12V battery replaced last year. Any ideas?
  10. dolj
    dolj Senior Member
    8,194
    4,174
    Wellington, New Zealand
    Have you checked the voltage on the fob battery? If it is 2.9 V or less replace the battery It takes a CR2032 lithium cell. Check the voltage on the new battery, don't assume that because it is new it is good. A new battery should be 3.3 - 3.4 V if it is good.
    That's the only thing I can think of at the moment.
  11. Vicki1959
    Mechanicsburg PA
    It happens with both keyFOBs, and we have checked voltage. It's a weird problem, I admit. I'm wondering if the car has a sensor that is going bad. But I don't know anything about sensors in the Prius or any car.
