2007 Tail light removal instructions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by msoengineer, Jan 6, 2008.
  1. msoengineer
    msoengineer New Member
    Tail light removal instructions w/ pics
    Long story short the top layer lens cracked on my left tail light. You can't replace just the lens it's all one complete assembly as others have mentioned in other posts.
    I decided to take a few pictures to help out others.
    Tools you will need-
    1-10mm 2" long socket and wrench plus 3" extension
    2- Smaller width flat blade screw driver.
    3- Strong fingers
    4-Gentle Touch
    Steps to reach tail light assembly (mine was the driver side tail light).
    1-Fold Down the rear seats
    2-Remove the privacy trunk blind bar
    3-Remove three seperate 10mm bolts as shown in pictures:
    Pull the silver toggle out once you pull the bolt
    Inside that hole is a super long bolt-Use the wrench extension here
    4-Pull the trim away from the car to expose the hidden retention clips and pull out the clips:
    5- Pull the plastic trim apart:
    5a- Start in the back
    5b- Pull down and out in the middle:
    5c- Pull back, down and out at this area. I grabbed where the shade slides into- this will require extra force:
    6-Remove the trunk light wiring clip:
    7-Un-clip the tail light harness using a small width flat head:
    8- now that everything has been separated from the wall you can pull/push the carpeting away from the tail light assembly and remove the two bolts for the tail light using the 2" long 10mm socket:
    Bottom Bolt
    Top Bolt
    Tada- now just push the assembly out from the inside and put the the new one in place.
    Follow the steps in reverse to put it all back together.
    Remember to be gentle yet firm when you pull all this stuff apart. I've pulled off trim in the past and it takes some finesse and skill to not break stuff.
    This should be a 15 minute job to do .
    It cost me $165.00 to get a replacement assembly from my buddies auto body shop.
    I used my cell phone to take these pictures so I apologize if they may be poor quality
    Feel free to PM me with any questions/issues.
    Tom
    kmsbanr, Bjorn45, BBBruce and 13 others like this.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Don't apologize about the pictures, great info.
    Thanks
  3. notmyrealname
    notmyrealname New Member
    PA
    Dear msoengineer- I had a small break in my driversside taillight that I had patched with clear ducttape and it was just fine. But my 07 didn't pass inspection (FY TiresPlus PA). TP wanted $350 to replace it. Well, thanks to Your excellent instructions I ordered the part on Ebay for $130 and replaced it myself! Took this girlie about an hour; first repair I ever attempted. Thank you so much, I did not break anything in the process and it was a great boost of self-confidence. Bless you dude!
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Well done notmyrealname and thanks to the OP for posting this thread.
    PriusChat has saved me thousands of dollars, it really has. Thanks everyone!
  5. zinndeadly
    zinndeadly New Member
    Los Angeles
    MSO
    just wanted to say thanks for your clear explanation and pictures...thanks for taking the time to share your knowledge....Got my replacement tail assembly on EBay for $110 and installed it in under 20 minutes!!!
    be easy
    Zinn
  6. splunge
    splunge New Member
    Northern CA
    Thanks a bunch for the great article.
    I was able to replace a broken driver's side brake light; however now the turn signal the light itself doesn't work! Any ideas how to troubleshoot this problem?
    Thanks in advance.
  7. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    The turn signal is a regular bulb. Make sure that it is good, and properly installed.
  8. splunge
    splunge New Member
    Northern CA
    Gah. Yeah. I replaced the part and forgot to install all of the other light bulbs. Once I did that it works like a charm.
    Thanks for the pointer. :)
  9. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Re: Tail light removal instructions w/ pics
    Great job. Another "how to" to add to my list.
  10. Speedwing
    Speedwing Junior Member
    48
    Southeast PA
    Bought a new unit on E-Bay to replace my cracked lens (parking lot tap, crack and run). Thanks for the write-up and pics. My passenger side replacement went very smoothly.
    BOB
  11. donalmilligan089
    239
    22
    virginia usa
    Is passenger side about the same? I just bought new lens on ebay for 98.95. Seems to be a good deal. thanks for the write up and pics .My 2006 looks different -no interior light
  12. josfjr
    josfjr New Member
    Glendale, Az
    Hello all,
    after removing the bolts i still can not push the assembly out. On the last pick showing the bolts there is a pink (top) and black (bottom) cap that are next to the bolts. Are those suppose to come off? thx
  13. archiveman2977
    archiveman2977 archiveman2977
    49
    Central Texas near Austin
    2013 Prius v wagon
    Good News, Guys...Amazon.com stocks 2009 Prius taillights! I ordered Wed. through Amazon Prime and received the driver's taillight today, Fri., 2-day air free shipping and no tax. Price $98.82.
    And along with the great instructions and pictures, it is now installed.
    When in doubt, consult PRIUSCHAT.
  14. tdcaum
    tdcaum New Member
    PA
    Thanks for putting these tail light lens removal instructions on the forum. Saved me a lot of money.
  15. jdrogers2
    jdrogers2 New Member
    Granite Bay CA
    Thank you so much for this excellent and most helpful post.
  16. 2004and2010
    2004and2010 Junior Member
    Columbia, CA
    Regarding 2007 Tail light unit: Thanks for your clear directions and excellent photos. The LED stoplight went out on my 2004 Prius and needed replacement. When I discovered it was not just a simple bulb replacement, I felt stuck, but you made the stops clear. Thanks. 2004and2010
  17. jimdsm
    jimdsm New Member
    Iowa
    Another post I read on the internet said you should disconnect the battery before doing this. Is that really necessary?
  18. BostonPete
    BostonPete New Member
    Mass
    Thanks for the nice directions. Got a drivers side unit to replace weakly glowing LED stop light from AM autoparts on eBay. $80 free shipping. Got 2 days after I ordered. Seems to work OK and looks the same as the other one.
    I was a little surprised by the white nylon bolt caps that had to be pryed off the 2 bolt heads on the old unit, but other than that it went pretty well. I found it easier to use a 10mm end wrench to loosen the nuts on the lamp unit bolts. The socket was fine for the interior nuts and bolts.
  19. stillageek
    stillageek Junior Member
    52
    Hmm Pried off Nylon bolt caps? I replaced my 2004 tail lamp with an aftermarket unit....it was one for one. I think I just moved over the other bulbs from the old unit.
  20. tlessard
    tlessard Junior Member
    Austin
    Excellent thread! Just swapped my 2005 RH tail light in less than half an hour for less than $70 shipped from modernautomotiveparts.com. That was waaaay too easy! Thanks! :)
