2007 Toyota Prius broke down with several hybrid system codes, but shops says it's actually fine?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chrissy, Jun 23, 2014.
  1. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,438
    3,306
    Madison, Wisconsin
    I think Avi is on the right track.
    If the 12v checks out fine, I would I would say you are likely headed for a very expensive repair in the near future.
  3. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Good or bad 12V battery, you have a bigger battle to win.
    Doesn't look good based Luscious' Garage experience, documented in the article above.
    Bad News: You got bad service from the dealership you went to for a diagnosis (DARCARS Toyota in Silver Spring).
    Good News: 1) The article from Luscious has a lot of documented information which a knowledgeable Technician should understand.
    2) Luscious also refers to a TSB (Toyota Service Bulletin), which should help you out; attached below.
    3) I believe Maryland adopted the CARB (California Air Resource Board) Emissions standard, beginning for 2007 model year and
    later vehicles; hopefully this vehicle has always been in a CARB state.
    4) Insist that your transaxle be covered under the CARB warranty as indicated in the attached TSB.
    5) Dealership will be getting the warranty work, so there is a benefit for them.
    My 2007 transaxle was covered under the CARB warranty in Feb 2011, at 99,114 miles. No codes of any type were displayed. The car (rather the transaxle) was just making a consistent, rotational type noise, that increased in frequency and loudness, as the car went faster. Initially denied, bummed, out $100 for the trouble shooting fee, I was contemplating a repair or buying a used vehicle. However, the service advisor called me back a week later with the good news of warranty coverage. Clearly this service advisor went to bat for me, because he wanted the warranty work; I didn't even ask for this, and was already resigned to a repair or another used car. Push the lazy service advisor. You will likely be provided a rental while the transaxle is being replaced too.
  4. chrissy
    chrissy Junior Member
    Baltimore, MD
    Morning everyone!
    I had no idea I could check the battery myself through the Prius itself. I did that this morning before driving to work. The car had been off for a little over 12 hours. Here's what I got:
    ACC Mode: 12.4V
    Pressing the power button without the brake again: 12.1V
    Ready mode: 14.2V
    So these seem to be all within the healthy range. Is it possible that the battery had been drained when the car broke down, but it has now charged itself back up to a healthy amount just from me driving around for work (also, the shop put ~80 miles on it in road tests).
    At this point, it seems like the 12v battery is healthy and the inverter coolant is flowing like it should. The car itself is running perfectly and I haven't noticed any weird noises or anything. Should I stop worrying? Should I get a 2nd opinion at another Toyota service center? Is there anything else I should check myself?
    I am supposed to drive out to Leesburg, VA this weekend for an event for work. That's about 140 miles round trip. Should I cancel that? I really don't want to get stranded far from home, but then again, the car seems okay?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Watch the battery, and don't worry. If it was a low 12 volt battery, all sorts of failures could be false positives
  6. usnavystgc
    3,159
    990
    Tucson, AZ
    Chrissy,
    I don't know how to say any other way but, you car is completely fine. It is extremely likely (like 99.99%) that your 12V battery became drained while it was out of commission. I do not think you should worry any more and... Have fun in Leesburg. :)
    #26 usnavystgc, Jun 25, 2014
  7. Patrick Wong
    18,207
    6,507
    I disagree that your car is completely fine. Rather, it has an intermittent high voltage ground fault which will eventually reappear.
    Now, it would be OK for you to drive the car on a road trip except that once this fault is logged, the car will refuse to start. So, as a workaround, if you are prepared to disconnect the 12V battery for a few minutes, then reconnect it, you will be able to make the Prius READY and drive away.
    The purpose of disconnecting the battery is to allow the various ECUs to power down and reset. This clears the DTC memory in the hybrid vehicle ECU which is the one logging the serious failure codes.
    So I suggest that you make sure you can find the 12V battery and are prepared to disconnect the negative battery cable where it bolts to the body. A 10 mm socket and a 3/8" socket wrench would work well for this purpose.
    Good luck.
    #27 Patrick Wong, Jun 25, 2014
  8. ericbecky
    4,438
    3,306
    Madison, Wisconsin
    Read the article from Luscious Garage garage above. Then see if it matches up with the issue that your Prius is exhibiting.
    Please keep us up to date if the symptoms return.
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    Well this looks like a case of too many hands spoil the soup so I'm bowing out but my assessment is that the 12V became weak/discharged and caused the problems. I'd be very surprised if you have problems with it in the near future.
  10. chrissy
    Baltimore, MD
    everyone! I meant to come back to update you sooner but it slipped my mind since life has been busy, busy, busy!
    The car has been perfectly fine! I have been on long drives and short with no issue. I still get a little worried that something will happen, so I will keep in mind what Patrick Wong said about disconnecting the 12v battery (I'll learn how to do that this weekend).
    Thanks everyone for your advice, insight, and help! I appreciate it so much. Hopefully my little Prius just had a glitch or a drained battery.
  11. Patrick Wong
    18,207
    6,507
    Thanks for the update, looks like usnavystgc was correct with his assessment!
    Chrissy, if you have driven 2K miles or more without a recurrence of those DTC being logged, I would agree your car is good and there no longer would be reason for concern. Good luck.
    #31 Patrick Wong, Jul 16, 2014
