2007 Warning Lights: All, Some, None
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SarcasticFringehead, Nov 10, 2025.
  1. SarcasticFringehead
    SarcasticFringehead Junior Member
    47
    UK
    Got into the 2007 just now to run the engine for 5 min.
    It ran fine for 2 min.
    Then the red triangle came on, with the engine and brake warning lights.
    Turned it off and on again.
    Red triangle again, this time with VSC and brake warning lights.
    Red triangle again, this time with all the warning lights.
    I hope it’s only a corroded wire like last time. I’m waiting for the garage to call back.
    Meanwhile, anybody else experienced this?
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Now's the Time to read your codes to see what cars telling you. A corroded wire great . Why you on salt or full time wet? Car sits forever turns into terrarium in season changes ? Prius aren't sitting types of vehicles!
  3. SarcasticFringehead
    47
    UK
    I don't have a code reader.
  4. ChapmanF
    18,959
  5. SarcasticFringehead
    47
    UK
  6. Tombukt2
    13,809
    2,504
    Durham NC
    Maybe the garage will tell you the codes they repaired
  7. SarcasticFringehead
    47
    UK
    I'm sure they will.
    My question was whether anyone else had had a similar experience. It seems no-one has.
  8. ChapmanF
    18,959
    As there are a couple hundred reasons for the triangle to come on, and a similar number for the brake system lights to come on, it's a good chance even someone else's "similar experience" would have had unrelated causes. Best just to wait to know what the trouble codes are.
