2007 Windshield Washer (front and back) inoperative
Discussion in 'Gen 2 Prius Technical Discussion' started by Rick 432, Oct 4, 2022.
  1. Rick 432
    Rick 432 Member
    112
    29
    My 07 Prius the windshield washer stopped working the other day. This is what I did. I check the fuse under that dashboard and both sides of the fuse have power, I checked the washer delivery hoses and they appear fine, disconnected the electric connections at the pump and there is power with the car on so I don't believe it is the switch (but I could be totally wrong about that) and finally I had someone in the car turn on the washer pump and I did not feel or hear the pump motors activate at the reservoir Front and back pumps are inoperative. This is my first Prius so I am unsure if these washer pumps fail a lot. Odd that both pumps are not working but I did not check the rear pump when I bought the car 6 weeks ago. Any thoughts would be greatly appreciated. Thank you! :) Ps. I saw replacement pumps on Amazon for about $12.00. ??? Thanks!
  2. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    There was a recent thread on similar issue
