2007 with 20,000mi - too low miles???
Discussion in 'Gen 2 Prius Main Forum' started by gailsgoal, Mar 17, 2013.
  1. gailsgoal
    gailsgoal Junior Member
    16
    Bainbridge Island
    Hello and good morning,
    Can anybody help with some information please, this may be and seems as though it shouldn't be - a problem.. but
    I'm still searching for a prius and I've come across a 2007 second gen, one of the higher packages. It has approx. 23,000 miles on it.. - My question is: Is this too low of miles for how old it is??
    Could the low miles indicate potential problems with not having been driven enough? .. is that possible?
    I've searched the site and can't seem to find any information on this.
    thanks so much,
    love the site
    cheers .. now out to the garden
    JMD likes this.
  2. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    People on this site have been speculating that the battery's life is about 10 years, it is in fact warrentied for that length of time. Probably the concern with that mileage would be the health of the 12 volt battery, assuming it is still the origional battery. Prius batterys don't do well if they are allowed to run down too often for lack of use, but it is cheaper to buy a 12 volt, than an additional 30 thousand miles. If you have the car checked out by a good Prius mechanic, you probably have found a gem, good luck.
  3. gailsgoal
    16
    Bainbridge Island
    yikes! Thanks so much for the reply. Not sure if I'm doing this right - responding I mean..
    The car is a touring, not sure if thats a good idea but the price they're asking is $18,000, toyota certified.. What do you think? still sound like a gem??
    opinions are great - isolation is dreadful..
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The price seems a little steep for a 2007 but I can understand it with the low miles.
    In this area you can find Certified 2009's and used 2010's for that price. These are all with 3X the miles on them though.
    If it were me I'd aim for a Certified 2010, even if it had 70,000 miles on it. Part of that is because I live in the rust belt and the age of the body & chassis is very time dependent (as well as the traction battery as mentioned above). Also a high miles per year car probably has had relatively easy miles, unless it's been used as a taxi or rental car.
    For the most part these cars don't seem to have much in the way of chassis issues (front end, brakes, etc.) with accumulated miles.
    If you do go for the 2007 insist on a new 12V battery installed by the dealer.
    [Edit: Looking back at your greeting (and the time it was posted) I'm going to have to assume that you don't live in a high corrosion zip code.]
  5. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  6. gailsgoal
    16
    Bainbridge Island
    hmmm, blue book says 3,000 more and the question of salt on the road in enviro washington is nil I would think - body looks perfecto.. , not going to finance b/c that would mean paying more! Well, maybe its a good thing then.. wonder if its still there.
    Sure appreciate all the thoughts -
    any more are definitely welcome!
  7. gailsgoal
    16
    Bainbridge Island
    oh, I'm sorry - you said zero financing.. is easter a holiday?
  8. Patrick Wong
    18,210
    6,517
    There are two possible problems that I can think of:
    1) The 12V battery, if original, likely needs to be replaced due to the low usage which means the battery has spent most of its time being semi-discharged, which will shorten battery life.
    2) Unless the engine oil and oil filter was replaced at least annually, it is likely that some sludge has built up in the engine. Check the vehicle maintenance records to make sure that periodic engine oil changes occurred.
    JMD likes this.
  9. gailsgoal
    16
    Bainbridge Island
    Interesting, the carfax shows anual maintenance performed but does not necessarily indicate oil change, although done at the toyota dealership. My understanding is they do that either every 5,000 miles or, what is it, yearly?
    The other thing I just saw is that they have just put in a new "steering shaft repaired or replaced" - what would that be about? No accidents reported.
  10. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    That's a Recall that's being done on most Gen IIs. Nothing to worry about on that.
  11. JMD
    3,779
    1,282
    You may be OK on price. Sounds like a good deal.
    Steering shaft not sure. My BMW the seal for the shaft had to be replaced.
    Are you buying from dealer with a warranty?
    Looks like a good car.
    May want to have a Mechanic inspect it and give an opinion on sludge
    Drive the car and make sure I drives good.
  12. JMD
    3,779
    1,282
    Best you get it before it is sold. But for $6,000 more I'd get a brand spanking new one but that's me.
  13. gailsgoal
    16
    Bainbridge Island
    I'd love the solar roof on the new ones but think I'd get a bit clostraphobic (psych nurse but can't spell the word!) with the middle consol, also think I'd get food bits in the buttons since I practically live in it with long waits for the ferry commute to work.. although I do think they drive a bit nicer.
    Even 18,000 is a lot of money! .. do appreciate the help though - hand holding is a good thing.
  14. JMD
    3,779
    1,282
    The 24K model has no solar roof.
  15. JMD
    3,779
    1,282
    If it was me I would not spend $18,000 for a 7 year old used car. Sure it has low miles but at 10 years old stuff starts going wrong and it is expensive. the Traction battery has a 10 year life span that will be replaced in 3 years. For 6 thousand more you get a new car that will give you ten years of worry free motoring. To me it's worth the extra money.
    Nothing worse than car troubles. Why risk it?
  16. JMD
    3,779
    1,282
    A new traction battery replacement at the dealer is $4,200. Forget about the other stuff. What about the headaches and stress. Sure there are low cost salvage parts but do you want to go down that rat hole.
  17. gailsgoal
    16
    Bainbridge Island
    Ok, so it sounds like what I need to do is:
    1. ask the mechanics at the dealer what the "recommended maintenance performed" in actual fact was (since the sales man is a bit slimy and I don't trust him) to make sure that the oil has been changed yearly.
    And
    2. Have them show me the date on the 12v battery - if its the original battery from 07, ask them if they'll replace it.
    3. check that the steering shaft was a re-call fix.
    good information - ta
  18. JMD
    3,779
    1,282
    30,000 miles is recommended drain and fill of transaxle fluid, should cost about $100
  19. gailsgoal
    16
    Bainbridge Island
    Would that be done under the certification warranty if reached 30,000 miles within the year?
  20. JMD
    3,779
    1,282
    No that is your responsibility. I suggest doing it. If the dealer tries to upsell you to the flush just tell him the Drain and full.
    Transaxle failure is expensive and can be avoided by replacing the fluid the first 30,000 miles and every 60,000 miles thereafter.
    PCV valve which reduces sludge buildup should be done at 60,000 miles.
