2007 wont start. Only shifts to neutral.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MonkButter, May 19, 2019.
  1. MonkButter
    MonkButter Junior Member
    Ny
    Started this morning. Loud fan noise and gas barely moved car 8 feet. Stuck in driveway now, all dash lights on with symbol of red car with exclamation point on upper left of screen. Only shifts to park? Any ideas?
  2. MonkButter
    Ny
    52,789
    welcome!
    12v battery? hybrid battery? inverter pump? you need to read the trouble codes with tech stream.
    how many miles on her?
  4. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    I have an idea. Get a mini VCI and a copy of Techstream, read the codes, get back to us with them. Pictures of the warning lights never help.
    Raytheeagle likes this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    What lead up to this?
    Anything special last night. Like an oil change or any other work you did to the car?
  6. JC91006
    16,933
    8,643
    From the looks of it, your car is not in Ready mode, so it hasn't started. I would look at your 12v battery first, before you start spending tons of money
    Skibob and Raytheeagle like this.
  7. Patrick Wong
    18,210
    6,517
    Your car has a serious problem, indicated by the MFD red car icon. It has a hybrid drivetrain issue, perhaps a bad high voltage traction battery given the fan noise. You will need to retrieve the diagnostic trouble codes to pin down the issue.
  8. bisco
    52,789
    welcome!
